truck info wanted
/ truck info wanted #42
I don't think Petes and Kenworths have crew cabs do they? Or can you put seat that are leagal in a sleeper?
You can readily find 330-335 Petes, T300 KW's Freightliner FL's and M2's, and IH's with crew cabs marketed to the horse crowd. Power wise, they are going to have 8.3 Cummins, C7/3126 CAT's, Mercedes, and DT466's. Not the HP builder suggested. Expect to pay.
If you can live with a sleeper outfitted with with a seat, the market is in your favor. Single axles sleepers are far and away not as easy to find as tandems but they are out there. I don't know if you want an auto or a stick but the auto is also going to be more scarce.
Also, you can get a lot of truck for your money if you step from the Class 6's to the Class 7's.
/ truck info wanted #43
If you're going to pull a heavy load, do it the White way. As most everyone has said, you need to look beyond a pickup. A Ford F-450 pickup is rated at 33,000# GVWR but it won't be enough truck for your weights. You're in the International 4900, Ford F-650, Chevrolet 6500 territory. Lots of used beverage trucks equipped with air brakes and fifth wheels. If you bought a truck with air brakes you can use an air/electric brake controller for use with trailers with electric brakes.
That's one honey of a White. Congrats on the restoration.
/ truck info wanted #45
No offense, but I'd take my Duramax any day over the CAT C-7 in that freightliner:laughing: . 7 litres is not enough for the kind of load the OP wants to pull.
You need at least a 10L mill for towing a 30K trailer without struggle. trust me. You'll get bitten by the HP bug and with you had an M-11, N-14, etc.
I pull a 25,000lb trailer with my 4800. I have a DTA466 factory modified to 250HP and then tweaked even more by me up to at least 275HP and I wish I had more.
/ truck info wanted #46
Mostly, I was pointing out the cost of admission and following up on my previous thread on what's out there.
My FL70 has a 3126 (the C7 predecessor for those who don't know) and it does just fine with a gross in the low thirties. One of the trucks I drove delivering pole barns was a Pete 335 single axle, C7 8spd pulling a tandem roll off for delivering trusses. As I recall, the GVCW it was licensed for was around 56k. It would "wimper" at the smallest of hills.
I don't care for M-11's but that N-14 pulls and gets good mileage. So does the C-12 CAT.
Here is one all set up, plenty of seats with belts, a drop down sleeper berth, plenty of HP with an autoshift.I would not want it if my use involved farm or job site use. Great for the road though.
/ truck info wanted #50
I don't know much about big trucks but had a friend buy a Pete several years ago and got the tandem converted to a single axle for free by letting the shop keep the tandem stuff. He told me older tandem tractors were near worthless compared to a single. Worth thinking about????
/ truck info wanted #51
YES. The best choice for a heavy hauler is an old road tractor. They have lots of HP and comfort compared to a medium duty. If I were going to pull a 4 car wedge, I'd get a S/A road tractor.
/ truck info wanted
I just found a company on the web that make a crew cab Pete.
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
HARDEE 5' ROTARY MOWER (A63291)
HARDEE 5' ROTARY...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
