JD fittings
/ JD fittings #1
whitedogone
Gold Member
Central Illinois
JD 4120
Can someone post a link to the type of JD QC on my 4x20. I'm not sure what type they are called. I need to get a grapple ordered and need to rig up a Elec over HYD setup. Where's the best place to get these parts?
/ JD fittings #2
Whitedog,
I just went though a similar on my JD 4400. They were 3/8" ISO-B on the back. 1/4" ISO-A in front.
Pioneer style is ISO-A, and has a shorter face to rib measurement.
For fittings, I used discount hydraulic hose. They were really good with my returns and when I ordered the wrong parts, they credited me before even receiving my return. I'll gladly do business with them in the future.
Joe
/ JD fittings #5
Like KennyD said, your local dealer, then you know they will fit. Some "interchanges will work better than others. Would guess they will be around $10 - $15 each.
Roy
/ JD fittings #6
Let me try and clear up the "mud" for you. I'll include links to our web site, where you can order these online.
ISO-B refers to ISO 7241-1 Series B Couplers
700-06-06S = 3/8" complete set (1 male, 1 female)
701-06-06S = 3/8" female coupler only
702-06-06S = 3/8" male coupler only
ISO-A refers to ISO 7241-1 Series A Couplers
600-04-04S = 1/4" complete set (1 male, 1 female)
601-04-04S = 1/4" female coupler only
602-04-04S = 1/4" male coupler only
ISO-A and ISO-B couplers look very similar, but they are not compatible with one another.
/ JD fittings #7
Thanks Ken:thumbsup:
/ JD fittings #9
Is there any compatibility between A, B, and the Ag fitting??
Do the A and B always have that 'pointier' depressable nipple in the center and the Ag-style always have the ball??
-Jer.
/ JD fittings #10
I believe the ball and poppet type QD's will work with each other, The difference is in the shape of the parts. Poppet type connectors let the fluid flow better. More flow.
/ JD fittings #11
-Jer.
Like HHG wrote, they are NOT compatible.
The "pointer" is called a "poppet"
/ JD fittings #12
ISO Agricultural Tips
Ball Valve and Poppet Valve Models
The International Standards Organization (ISO) has adopted standardization requirements for interchangeability and performance of 1/2" agricultural male tips. SafeWay's S71 Series male tips, with either ball check or poppet check, meet or exceed these requirements. To date, all tractor manufacturers have accepted ISO 5675 as the "standard" for their equipment. SafeWay's 1/2" S20 Series and S70 Series female couplers accept all ISO 5675 male tips.
Configure & Compare ISO Agricultural Tips PDF | CAD
ISO agricultural tips
http://www.safewayhyd.com/pdfs/agricultural-tips-oem.pdf
In simple terms, just match up to what you have or change them all out to match.
The numbers on the fittings will cross over to another brand, if necessary, or use adapters.
/ JD fittings #13
I'm switching everything to one common type, I'm just not at home right now to know whether I have "A" or Ag style.
-Jer.
/ JD fittings #14
-Jer.
Your tractor should have the ISO-A 1/2" style that HHG linked above.
/ JD fittings #15
That's what I thought, but I was confused when I picked up my Schulte blower last week. It had the "B" type on it, and the partsman at the JD dealership told me those where "JD" style male connectors.
There all "A", or maybe "Ag" now.
-Jer.
/ JD fittings #16
The Agricultural Couplers (Pioneer, ISO 5675) are interchangeable with ISO 7241-1 Series A, but ONLY in one size (1/2"). All other sizes are not interchangeable. ISO 7241-1 Series B does not interchange with any of the others.
Most manufacturers will offer all of the above in both the ball style AND the poppet style. However, the most common configuration is the ball style for the Ag couplers, and the poppet style for the others. This is the way we list them at DiscountHydraulicHose.com, but the other styles are available as well.
2016 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A65053)
2016 BOMAG...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
2018 MULTIQUIP TOWABLE GENERATOR (A63276)
2018 MULTIQUIP...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2022 EZ-GO ELITE...
