JD fittings
   / JD fittings #1
whitedogone
Central Illinois
JD 4120
Can someone post a link to the type of JD QC on my 4x20. I'm not sure what type they are called. I need to get a grapple ordered and need to rig up a Elec over HYD setup. Where's the best place to get these parts?
   / JD fittings #2
Whitedog,
I just went though a similar on my JD 4400. They were 3/8" ISO-B on the back. 1/4" ISO-A in front.
Pioneer style is ISO-A, and has a shorter face to rib measurement.
For fittings, I used discount hydraulic hose. They were really good with my returns and when I ordered the wrong parts, they credited me before even receiving my return. I'll gladly do business with them in the future.
Joe
   / JD fittings #5
Like KennyD said, your local dealer, then you know they will fit. Some "interchanges will work better than others. Would guess they will be around $10 - $15 each.
Roy
   / JD fittings #6
Let me try and clear up the "mud" for you. I'll include links to our web site, where you can order these online.
ISO-B refers to ISO 7241-1 Series B Couplers
700-06-06S = 3/8" complete set (1 male, 1 female)
701-06-06S = 3/8" female coupler only
702-06-06S = 3/8" male coupler only
ISO-A refers to ISO 7241-1 Series A Couplers
600-04-04S = 1/4" complete set (1 male, 1 female)
601-04-04S = 1/4" female coupler only
602-04-04S = 1/4" male coupler only
ISO-A and ISO-B couplers look very similar, but they are not compatible with one another.
   / JD fittings #7
Thanks Ken:thumbsup:
   / JD fittings #9
Is there any compatibility between A, B, and the Ag fitting??
Do the A and B always have that 'pointier' depressable nipple in the center and the Ag-style always have the ball??
-Jer.
   / JD fittings #10
I believe the ball and poppet type QD's will work with each other, The difference is in the shape of the parts. Poppet type connectors let the fluid flow better. More flow.
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2017 KENWORTH T800 (INOPERABLE) (A53843)
2017 KENWORTH T800...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2007 GMC C4500 Mechanics Truck (A52384)
2007 GMC C4500...
2012 Talbert Lowboy T(4)-55SA-BC-HBG (A52384)
2012 Talbert...
