transmission overfilling ?
/ transmission overfilling ? #1
stormpetrel
Gold Member
Block Island R.I.
ym2210D
After putting the new hydraulics into operation I figured I should top off the transmission,what with some leaking from changing hoses/fittings, and all the new hoses/cylinder/valve. It's over-full.....considerably (read: I overfilled it, considerably:eek:). Is this dangerous? I know it's dangerous w/engine oil. Do I need to drain some out? Any help will be appreciated.
Steve
/ transmission overfilling ? #2
I would'nt think so. But If it was Me I would be losening the Hyd. drain plug.
/ transmission overfilling ? #4
I agree I doubt you will damage much but I would lower close to Yanmar mark. They put it there for some reason. I always give manufactures of equipment the benefit of doubt.
/ transmission overfilling ? #5
Is your transmition part of your hydraulics Storm Petrol (my favorite sea bird by the way) or are they seperate systems? If sepeate I would think you would be ok as long as there is enough room for the expansion of the oil when it gets hot, but if it is one system I would drain it asap. Good luck.
Rick
/ transmission overfilling ? #6
It should be a drain bolt/plug just like the oil pan. Just Losen it and let a slow drip or drain come out. When it drops to he correct level snug it back up your be fine. I would keep it also prob. nothing wrong with it.
Thanks, guys.....will drain some out. One reason I overfilled it is that I never saw fluid from the fill hole while filling.. It was only when I thought to myself "gee, this sure is taking a lot of oil" and checked, I saw it was at least a half inch overfull.
/ transmission overfilling ? #8
ya know what your wife or mother done with her turkey baster:D
she wouldn't missit till next turkey day;) then you slip out and buy her nother, and you'll always have a tool for such reasons in the future:cool:
/ transmission overfilling ? #9
Just what i was thinking Deep. He could go to Dollar Tree and get one for a dollar in there cooking isle.
/ transmission overfilling ? #10
turkey baster is good but a large syringe such as one for medical I.V. set up is ideal... you can suction fluids out of containers and they can be emptied into tight places such as 4x4 truck transfer cases,etc....my wife is a nurse so i get these and a supply of latex gloves for keeping hands clean
/ transmission overfilling ? #11
my wife is a nurse so i get these and a supply of latex gloves for keeping hands clean[/QUOTE]
Welcome Motored. seen your other post also You Poor Guy:laughing: My mother retired as a Charge Nurse or Head Nurse since back in the Sixties. And the Med. Syringe not me you never know were it may have been :ashamed::laughing:
Joking I have one also.;)
Carey
/ transmission overfilling ? #12
Those large syringes work well for changing power steering fluid in you'r vehicles as well...
/ transmission overfilling ? #13
1/2 inch or even an inch is not something to worry about. The trans level is a minimum level. I know that those with a FEL or other large hyd users deliberately overfill so that they are assured of at least a minimum when cylinders are extended.
Mike
/ transmission overfilling ? #14
Manual transmissions usually run the oil at about half the main gear diameter for a couple of reasons. 1) the gears will throw oil up into other parts such as the shifter linkage and bearings higher up in the case and 2) the oil seals are not designed for pressure. They are designed to keep small amounts of oil from leaking out that creeps down the shaft.
Too much oil can cause some seals to leak and prevent other parts from getting lubricated. Slight overfilling won't cause problems but if you fill it above the gears you could eventually have problems.
The slow speeds at which tractor gears rotate would probably never be an issue even if you overfilled it by quite a bit but you may see some seals start to seep.
/ transmission overfilling ? #15
I measured my loader cylinders. Curl cylinders are 1" rods with about a 14" stroke, lift cylinders are 1" by about 18" stroke. If my math is correct that could amount to 3.4 quarts. I check mine with cylinders extended and allow the fluid to be a little low trying to have a balance on not being way over full when cylinders are retracted. It would be very doubtful I would ever run for extended time with all cylinders fully extended.
/ transmission overfilling ? #16
I would think it would make no difference whether the rams are extended or retracted once all of the air is purged from the system. The same amount of oil will remain in the system either way. What goes out one side will be comming in on the other side. There will be a small amount more needed for the piston side of the cylinders vs the ram side but not much.
I don't see any difference on my dipstick with the rams extended or retracted.
/ transmission overfilling ? #17
Gary, look at it this way, if you have a cylinder full of fluid and push a 1" rod into it 18" that is going to displace 1" x 18" of fluid. That 1" x 18" of fluid goes back into the transmission.;)
/ transmission overfilling ? #18
True, but also the other side of the cylinder is filled by the pump at the same time and that came from the transmission. What goes out also comes back in. More or less.
/ transmission overfilling ? #19
No more, no less, 1" x 18" worth of fluid is displaced.
/ transmission overfilling ? #20
I dont think you understand what he is saying. I too think your not seeing this the correct way.
As a hydraulic cylinder is conpressed fluid will leave that compression side and flow to the resivoir, but to get it to compress fluind is being pumped in the back side of the piston just as fast as its leaving that side its compressing. This is assuming no air in a system, which unless just replaced a line or something there should be none.
Lets just say that 2 quarts is displaced by that piston compressing that same 2 quarts will not fill the resivoir 2 quarts higher than the current level as 2 quarts need to fill the area that the piston has traveled from on the back side of that piston. This is afterall what makes it compress, the fluid on the back side under pressure and the compressed side not.
NexTier Frac Manifold T/A Trailer (A60352)
NexTier Frac...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61307)
Bulk Lot of over...
TRANSPORT SYSTEMS 35LX AD DOUBLE DROP (A60736)
TRANSPORT SYSTEMS...
2025 AGT QHT500FL (A60463)
2025 AGT QHT500FL...
