John Deere 2240 4WD Brakes
/ John Deere 2240 4WD Brakes
Diff lock i think is manual pedal on the floor, so i think thats not the problem!
/ John Deere 2240 4WD Brakes #12
I was working from memory (not what it used to be). I need to install PMpro and Service Advisor on my personal laptop, if I'm going to keep this up. Thanks for keeping me honest. Still hard to imagine what might cause this problem. I would like to see if there is any debris in the suction screen.
/ John Deere 2240 4WD Brakes #13
Maybe put a TEE in the brake line with a pressure gauge and see if it's building pressure on it's own (something leaking thru the pedal valve?)
Or if you're able to SAFELY disconnect and plug both brake lines and test drive in a safe area and see if the brakes still drag. That would rule out the pedal valves.
/ John Deere 2240 4WD Brakes #14
Great idea. Maybe just plug one at a time, so you can still stop. That way you can isolate your problem depending on which side stops. Keep your speed down and be alert. This is a dangerous test. good luck.
/ John Deere 2240 4WD Brakes #15
When it is locked up what are the pedal reactions? Do you have play in both pedals?
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
Misc OKI Printer Cartridges and Image Drums (A59317)
Misc OKI Printer...
