John Deere 2240 4WD Brakes
/ John Deere 2240 4WD Brakes #1
brendan1
JOHN DEERE 2140 X-E SERIES
Hello everyone
Have a problem with my 2240 tractor it as locked the two back wheels up a
few times now as if the brakes were coming on and then will release again anybody any ideas?
Regards,
Brendan.
/ John Deere 2240 4WD Brakes #2
That's an '80's tractor with hyd. wet brakes ?
I'd be worried it is more than the brakes, but without more definitive info from you, wouldn't be able to venture a guess. Maybe others will come to the rescue.
/ John Deere 2240 4WD Brakes #3
I've heard using the wrong trans/hydraulic oil can cause the brake linings to be ruined.
Thanks for the answers.
Yes wet brakes it as locked up a few times after a drive of a few miles not doing it all the time maybe 3 times in as many weeks but will release its self after a few minutes.
Regards
Brendan
/ John Deere 2240 4WD Brakes #5
Another question.
If "locked up" means the wheels stop, then does just sitting still for a few minutes cause them to release? Does trying to go in reverse help any?
Or does "locked up" mean that something is dragging, and slowing down the tractor for a few minutes of driving time?
Do they "lock up" without touching the brake pedals, and do both brakes lock up evenly?
If not evenly, then one wheel would seemingly spin or you would/try-to go in circles.
If I lock up one brake, then that wheel will drag down the road/path.
Does it make a difference if in 4wd or not?
I'm thinking this isn't a brake problem. Convince me why you think it is. :)
Yes the two back wheel drag the road at the same time as if you put you foot on the brakes hard but then will release after a few minutes.
/ John Deere 2240 4WD Brakes #7
Seems odd to me that both brakes work together in this drag effect. I believe the linkage is independent from the brake pedal back to the left/right axles, so to speak. But there is a brake valve where the right left brakes are activated, so maybe that is a place to look for this dual effect. One pic shows the brakes and the valve (dotted) and the other the valve. There is a brake valve kit with o-rings and such, so maybe there is some wear and tear that this valve needs. That I don't know.
Regards the 4wd being engaged or not while this happens....what you say?
4wd is not ingaged the brakes are hyd. they are feed from the return oil of the steering motor when you press the pedal this feed the brake piston.
/ John Deere 2240 4WD Brakes #9
If they release after a few minutes, I almost has to be in the brake valve/master cylinder.
/ John Deere 2240 4WD Brakes #10
The return oil from steering does fill the brake reservoir, but at very low pressure. I can't imagine a brake valve making pressure on it's own. Maybe you've got a diff lock valve leaking past and trying to lock your diff at speed. I never tried to engage diff lock in motion (manual says not to). Is there a noise like maybe a gear binding up? What transmission?
Diff lock i think is manual pedal on the floor, so i think thats not the problem!
/ John Deere 2240 4WD Brakes #12
I was working from memory (not what it used to be). I need to install PMpro and Service Advisor on my personal laptop, if I'm going to keep this up. Thanks for keeping me honest. Still hard to imagine what might cause this problem. I would like to see if there is any debris in the suction screen.
/ John Deere 2240 4WD Brakes #13
Maybe put a TEE in the brake line with a pressure gauge and see if it's building pressure on it's own (something leaking thru the pedal valve?)
Or if you're able to SAFELY disconnect and plug both brake lines and test drive in a safe area and see if the brakes still drag. That would rule out the pedal valves.
/ John Deere 2240 4WD Brakes #14
Great idea. Maybe just plug one at a time, so you can still stop. That way you can isolate your problem depending on which side stops. Keep your speed down and be alert. This is a dangerous test. good luck.
/ John Deere 2240 4WD Brakes #15
When it is locked up what are the pedal reactions? Do you have play in both pedals?
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
LOT LOCATIONS (A59906)
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2017 FREIGHTLINER...
