W.R. Long third function kit
/ W.R. Long third function kit #1
jcliburn
Gold Member
Lawrence County, Mississippi
Kubota MX5100
I'm about to pull the trigger on a W.R. Long third function electric over hydraulic kit for my 2008 Kubota MX5100 with LA844 FEL.
I've called four different dealers in two states for pricing. Three quoted the identical price of $571 for the valve kit and $95 for the bulkhead plate, plus shipping/freight; and one quoted "about $1300" for the same outfit. Guess I won't be going with that last guy... (Shame too, because he was the closest W.R. Long dealer to me -- about 25 miles).
According to the dealer(s), the kit comes with everything I'll need -- valve, wire, switch, hoses, fittings, couplers, etc.
W.R. Long's web site says the most common location for installing the valve is the inside of the starboard FEL post. I guess I'll see if that's the best location when I get the kit laid out. I'd appreciate any hints from other users of this kit on similarly sized Kubota tractors.
I'm also interested to learn where you might have connected the solenoid electrical supply.
I might be consulting the experts here in the hydraulics forum in a week or two. :)
/ W.R. Long third function kit #2
Does Kubota make a 3rd function valve kit for the MX5100? If so, did you check on Kubota's price?
/ W.R. Long third function kit #4
Put one on L3130, real simple, just make sure you torque down all fittings so they do not leak. Went to fuse box and tapped the switched buss and put in a seperate fuse and holder in. When routing wires to switch from solenoid make sure not to get them into pinch points and I added spade terminal connectors to solenoid wires so if you wanted you could reverse switch logic for your own preference, dressed, sleaved and tied all wires up and works good.
David Kb7uns
/ W.R. Long third function kit #5
I didn't check, after reading posts on TBN complaining of exorbitant prices for Kubota valve kits.
I only ask because I bought a Kubota unit for my tractor. It fit perfectly... from plubling to electrical to the mounting of the valve itself. I could tell when I stalled it that it was made for my tractor. Sometimes a few extra bucks is worth it when it is made by the manufacturer specifically for your tractor.
My 3rd function valve was $900.
No biggy... just asking.
/ W.R. Long third function kit #6
I installed one (WR Long) on my L3400... It fit perfectly, from plumbing to electrical to the mounting of the valve itself... felt like it was made for my tractor, and was $400 less than the Kubota kit.
Not trying to be sarcastic... my point is that the WR Long kit is excellent. WR Long is great to deal with also... any questions and Nelson Long is only a phone call away. You will have no problem speaking to him directly, and he enjoys talking you through the solution to any questions you may have.
/ W.R. Long third function kit #7
The Valve is mounted with u-bolts in front of your right foot on the horizontal bar that is part of your loader frame. This kit is one of the easier ones to install. If you have any questions you are welcome to call.
Nelson
/ W.R. Long third function kit #8
I have gone about things just backwards, I suppose: I've purchased a 66" root grapple AND 3rd function valve kit (WR Long) and NOW trying to find out how to install it all. My tractor is a New Holland TC40DA (w/hydrostat trans, 16LA FEL, & back hoe). The 3rd function kit came with paltry instructions, but didn't account for having back hoe attached. I am sure there are tons of posts across the Forum on the subject and/or should start my own thread(?), but I am really stumped on how to hook up the hydraulics for this. Any help or even directions to proper thread(s) would be greatly appreciated.
/ W.R. Long third function kit #9
I happen to know the guy that designed this valve kit. Please call me and I'll be happy to help you with any questions.
Nelson
252-823-4570
Nelson
252-823-4570
What a great place TBN is! I think this Internet thing might just catch on.
I picked up my 3rd function kit today and will install it in the next few days.
Jay
/ W.R. Long third function kit #11
I had the WR long installed on my 2010 L4400, when I ordered it. I asked about a Kubota one, and the dealer said they don't even mention them to the customers, due to price. In any case, mine works, but it just seems to me that the manufactures, could come up with a better design. Oh yeah, do not, use the third function while your backhoe is connected to the Hydraulics. You will blow the seals out of your control valve assembly, due to back pressure. It is in the manual for your backhoe.:thumbsup:
/ W.R. Long third function kit #12
This is Nelson at W.R.Long.
If you are having back pressure issues with your backhoe with our valve then the valve kit is installed incorrectly. This valve is on many tractors with backhoes with no problems.
In fact when we designed this valve kit we were very specific with our requirements that our valve would be able to withstand 3,000 pounds of back pressure.
Our valve must be the 1st devise after the power beyond port on your loader valve and then your backhoe after our valve. If you like you can go to the valve kit section of our website. I would give you the link but I think TBH has a thing about us doing that.
If you have any questions I'll be happy to help. You are welcome to call Nelson 252-823-4570
Nelson, can I ask you a few questions?
I'm installing a W.R. Long 3rd function valve kit on a Kubota MX5100 with LA844 loader.
The first shot shows the kit (obviously). Am I correct to conclude that the coiled hose pair on the right isn't needed since I bought the bulkhead plate assembly (which is the coiled hose pair on the left)?
The second shot shows where I placed the 3rd function valve on the FEL spar. I placed it a bit outboard of center to avoid having the attachment hoses chafe on the hood. After thinking about it though, I believe I'm too far outboard and the quick disconnect fitting will be too close to the loader arm when the loader is mounted. Where do you normally position the valve on the spar?
The third shot shows the power beyond hose (with green tape on it) running from the 3rd function valve T port back to the manifold. This is the one that was originally connected to the power beyond port on the FEL valve. As you can see, there's a good bit of extra length now. Is it okay to just leave it with the big curve in it?
Last question. I'm not terribly familiar with the electrical layout of this tractor, and just about all the wires are bundled and sheathed. Can you recommend a particular wire to tap into for the hot? Is the idea to just cut the orange wire loop provided in the kit (the loop with the 10A fuse) and splice it between the tractor hot and the valve switch hot?
Thanks,
Jay
/ W.R. Long third function kit #14
Sure,
The hoses on the left connect to our 3rd function valve A and B ports and the other end connect to the back side of the bulk head plate. The hose on the bottom right connects to your power beyond port on your loader valve and our P port. The hoses you are asking about are connected to the front side of the bulk head plate and the other ends to the back of your attachment. As you know we manufacture attachments and valve kits. We decided years ago to include hose in the valve kit all the way to the back of the attachment.
By using the U-Bolts is give you the installer/owner the flexibility to move the valve around. I would get everything put together and the place the valve where you find is the best location and then tighten up the bolts.
No problem with the big curve. I would tuck it below the other hose and in toward the tractor.
I'm not familiar with the wiring on your tractor either. I would find a wire that is connected to your switch. Yes just cut the orange wire.
Thanks,
Also, you are always welcome to call us.
Nelson 252-823-4570
Thanks,
Jay
Sure,
Thanks,
Nelson 252-823-4570
Understood. Thanks. Will call if needed.
The bulkhead plate is angled (see first photo), but the bracket where I want to attach it is vertical (see second photo).
The holes in the bulkhead plate line up perfectly with the bracket, but if I install the angled bulkhead plate onto this bracket, the quick disconnect fittings will point toward the ground instead of straight ahead.
I suppose I could mount it with the couplers on the bottom, which case they'd point upward. Nelson, your recommendation?
Jay
/ W.R. Long third function kit #17
Jay
Can you bend the bracket straight?
I don't have a torch, but I suppose I could take it to a shop and have it done. I'd rather not, though, just because it's brand new and for my hard-earned money I'd like to have the correct piece out of the box. :)
I'm hoping Nelson will swoop in with sage guidance. I have a feeling he's going to tell me the correct orientation is the couplings coming off the bottom of the torque tube, pointing upward.
Jay
I called W.R. Long today. The angled bulkhead plate is appropriate for my LA844 loader and should be mounted upright; the couplings are intended to point downward.
/ W.R. Long third function kit #20
I purchased the elect over hyd kit from WR Long through my Kubota dealer to use on my bucket grapple. This thing is great if you want to spend the money.
Didn't take long to install and everything fit on my tractor like he said it would.
The only thing I couldn't use was the bulk head plate because it would hit my brush guard (home made add on) and tear the fittings off. I would recommend
this set up to anyone
2004 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2004 Ford F-250...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED IRANCH...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
