FF250 gets donated, need 1/2 ton replacement
/ FF250 gets donated, need 1/2 ton replacement #1
_RaT_
Super Member
Peoples Republic of Northern CA.
Kioti 3510-SE HST
I am donating my F250 not so much because I'm a good hearted person but rather I think it would be a disaster for anyone who bought it to try and get the thing in shape,
1. steering wheel bearings out
2. glow plug module out
3. front end springs totally shot
4. Horn/cruise control a mess
5. glow plug wire harness shot
6. interior door panels to dash falling apart
7. etc.
To me its a parts vehicle. The engine runs superb and the transmission was rebuilt about 20,000 miles ago.
I was thinking of a Toyota Tacoma but after doing the Craigslist thing, the used car lot thing etc, they are just overpriced. On top of that the MPG really is not much better than a full size.
I saw a used 04 GMC extended cab yesterday, test drove it, it was fine, a little loose, noise from the front suspension.
I am not a brand loyalist and generally like the used Chevy, Ford and Dodge in that order in terms of looks. (these are those trucks in the used 2008ish and earlier ball park.)
Not knowing squat about the GM trucks, I see a 4.8L V8 on Craigslist. Can anyone out there give me some advice on a 1/2 ton, crew or extended cab 4WD, I do not tow much of anything, power is not important. MPG is more important. Reliability is high as well. The Tundra and Titan while nice are just expensive out here as well. Either of those would be fine as well.
My List;
1. Used
2. 1/2 ton
3. mpg
4. extended/crew cab
5. 4WD
6. standard or long bed (no super short bed)
I have read some of the other posts but folks here are typically towing stuff, my needs are a bit different.
Thanks a ton, make that a 1/2 ton, Rat
/ FF250 gets donated, need 1/2 ton replacement #2
My List;
1. Used
2. 1/2 ton
3. mpg
5. 4WD
I have a 2005 Chevy 1/2 Ton 4x4 Regular Cab Long bed with 5.3L and 3.42 gears work truck trim.
It has a utility cap on it now but without it, it averaged around 16 on the country roads and 20 on the freeway if I stayed below 70. The cap sticks up above the cab, and has a ladder rack on it, so the mileage is somewhat lower now. The tires on it now are all terrain load range C (heavier sidewall), this seemed to drop the mileage some also. I had a '99 extended cab short bed that was probably 15/17 in the mileage department. It was 5.3L/3.73 geared truck.
In 5+ years it has needed an emissions solenoid near the gas tank, a new rear bumper (rust warranty), and an intermediate steering shaft (common GM issue). I replaced the brakes around 60,000 and it is on its second set of tires.
The 2005 - 2007.5 have a 17" diameter wheel as the front rotor is larger than the 1999-2004. The '99 I had, the brakes always seemed soft. The 2005 and up also have an electric fan which is supposed to help mileage some.
In a GM you can't get 6 1/2' or 8' bed in a half ton with a crew cab. You can in the regular and extended cab's.
We also have an '08 diesel Chevy with newer body style that shares the cab with the 1/2 ton. The cloth seats in it are attracted to lint, other than it has been OK.
/ FF250 gets donated, need 1/2 ton replacement #3
I really dont thing you gain much by going to the smaller V8 but you sure lose if you want to tow. For you if you do not tow much look for a GM 5.3 with 3.43 gears. It will get good mpg but your tow limit will be just south of 7,000#.
Chris
/ FF250 gets donated, need 1/2 ton replacement #4
Ah, if he really needs to tow, I guess I can go do it for him. We're only 1/2 hours from each other. Although, we never have had a Ca get together. Been yakking on this forum since '97 or '98, when it was a Kubota only forum. But drive 30 minutes to meet :D
Chris
I'm going to be somewhat limited by whats available out there. My question would be, if a 4.8L were to be in a truck I liked, whats the opinion of this engine. As far as rear end ratios, I also think I will be pretty limited to what comes up and at a price I like. How are GM's automatics?
Also knowing nothing about GM stuff, any years that were a particular issue? When were the model changes?
Thanks for both of your comments.
Chris
Thanks for the tow offer Robert, I have a couple of towers available to me if I need you know the 1 yard of concrete etc. I still have the Ford you offered to help yank out the old IFS and put in the solid axle as well as the leafs. You should see it now.
/ FF250 gets donated, need 1/2 ton replacement #7
If you get a chevy or gmc get it with a 5.3 and 373 gears ONLY the 342s get the same mpg unloaded as 373.. Now when u pull you really tell the differance. The rear ends are a little weak and the 342 cause problems. ( as well put more strain on tranny )
They all ( 4x4 and 4.8 or 5.3 ) get 16-18 highway.. If someone claims they got better there full of it... Mpg on 4.8 and 5.3 make no differance at all.. You xant tell the differance between the two motors unless loaded or towing. There only 10 hp differance between the two.
The motors ( 4.8 5.3 6.0 ) motors are bullet
Proof. They do have a little isssue know as piston slap though when cold...
Trannys are a little soft ( 3rd clutch pack, sprag and front sun star) but way better than a ford tranny and good for 150,000 hard towing miles.. Cheap to rebuild to..
Ive had 13 of them.... Not a joke..
Years from 1999s to a 05. I will only own a chevy gasser..
Buy it you wont be sorry.
/ FF250 gets donated, need 1/2 ton replacement #8
Where do you live? I've been looking for a parts truck like that...
I know you were going to donate to charity, but what if I can give you a cash donation to give them instead?
/ FF250 gets donated, need 1/2 ton replacement #10
Check the hours on the trucks that you look at. With key in the off position, hold trip odometer reset button until engine hours are displayed. Divide total miles by total hours to find the average speed over the life of the vehicle. I would stay away from any vehicle with an average speed under 30 MPH. These vehicles usually have extra wear and tear from being idled excessively and/or driven in city traffic.
/ FF250 gets donated, need 1/2 ton replacement #11
Thats only on some 01 and up trucks..
Mostly average moving speed is 43...
30 is getting down there.. Thats the average for on the road trucks.. 35+ Could be a intown truck, my moving average is 47 and im nearly 90% highway.
/ FF250 gets donated, need 1/2 ton replacement #12
I won't advise you as to what truck you should buy, but I recently donated a pickup and a car to Kidney Kars. I will probably do it again the next time I need to get rid of a vehicle.
I drive my vehicles until the wheels fall off. I don't want the hassle of trading or selling or giving an unreliable vehicle to an individual.
The vehicles I donated were driveable, but Kidney Kars insisted on sending a tow truck to my home and hauling them away.
I believe the tax rule now is that you have to use the actual price the vehicle brought at auction, rather than the Blue Book value, for your tax deduction.
Thanks and I agree about running the vehicle into the ground. Out here our vehicles don't rust so it takes a long time to run them into the ground. I am now getting nickel and dime'd to death.
/ FF250 gets donated, need 1/2 ton replacement #14
I
They just hold there value much better than the overpriced American full size trucks that depreciate 100% quicker.
there i fixed it for ya :thumbsup:
/ FF250 gets donated, need 1/2 ton replacement #15
In full size, GM is going to get as good of fuel mileage as any. If you're going to drive it into the ground and not tow, don't fret engine choice. If you ever plan to sell - get the 5.3, that's what most everyone wants.
/ FF250 gets donated, need 1/2 ton replacement #16
The 5.3 is a little gutless but is know as a good engine that can go 175,000 mile no problem. I know a couple guys with high mileage ones that start to have issues at that point. No real tranny issues. Steering wheel shaft issues have been present on GM trucks for about a 10 year period. Its covered if under warranty The only other issue I see with them is they seem to have the cheapest interior of all the manufactures but thats about it.
I would look at the F-150 with a 5.4. I have owned 6 personally and my family another 8 or so with no major issues. I have also had GM, Dodge, and Nissan trucks in the last 10 years so I have a fair comparison and I feel the F-150 is by far the best TOTAL package.
Chris
/ FF250 gets donated, need 1/2 ton replacement #17
I choose my F-150 on a couple of items.
1.) It got 1 mpg better than the chevy
2.) It has rear disc brakes and the chevy had drum
3.) Sync system
4.) Wife liked it better :)
/ FF250 gets donated, need 1/2 ton replacement #18
3.) Sync system
According to all epa mpgs. The chevy beat the f150 5.4 and 4.6 by at least 2-3 mpg.. The f150s ive had got 14-16.5. Again 4.6 got worse than 5.4 but the 5.4 blew spark plugs out of the head for fun..
( ford has problem with this in the 5.4 and 6.8 engines due to only 4 threads in the hole.)
Btw, All 1998.5 up gm trucks have rear disk brakes...
/ FF250 gets donated, need 1/2 ton replacement #19
I've got an 04 GMC 1/2 ton with the 5.3 and 3.73 gears. 147K miles and realitively trouble free. Just replaced the alternator last week with the higher amperage unit (155 amp). I have replaced three front wheel bearing, replaced the transfer case due to over torquing the drain plug and cracking the case (obviously my fault), the steering shaft bump (not fixed, just live with it), and emergency brake work. Brakes are a common maintenance issue, but not any worse than my previous Fords. I try to keep up with maintenance and frequent fluid changes.
Others have given good advise. MPG is usually between 16 and 20 mpg, based upon driving conditions, weather, speed, etc.
Build quality is better than previous generations and from experince with my fathers new 2011 HD, I personally feel that these trucks are builts better than the new ones. Generally I have driven my truck easily, but it has worked hard, towing heavy and plowing snow.
I plan on driving mine daily until 200K and then retiring it to a plow/farm truck. Its been a great truck and I don't plan on letting it go.
/ FF250 gets donated, need 1/2 ton replacement #20
My research found the mpg were not that far apart. I test drove both trucks over a few days and found the f-150 got 1 mpg better.
You can look at the chevy web site and rear drums is still standard on the silverado
I put 160k plus miles on a 5.4 with no problems.
Daytime Running Lamps Standard Standard
Traction Control System Standard Standard
StabiliTrak Electronic Stability Control System Standard Standard
Front Disc/Rear Drum Brakes Standard Standard
4- Wheel ABS Standard Standard
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 CAT 305C (A53317)
2019 Felling Trailers 9 Ton T/A Flatbed Equipment Trailer (A59230)
2019 Felling...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
Broom Attachment (A59228)
Broom Attachment...
