hydraulink for 3 Point Toplink
/ hydraulink for 3 Point Toplink #1
RamTruckMan
Anyone ever use this product? Requires no hookup to hydrualics. Evidently, just push or turn a knob, push toplink in or out, turn the knob back to set at desired lenght.
/ hydraulink for 3 Point Toplink #2
What product?
/ hydraulink for 3 Point Toplink #4
Be very very careful. Think twice before installation of a cylinder. Measure all possible positions of an implement the cylinder will be used with so to select correct dimensions. I'm also planning to install hydro toplink. Have not decided yet.
/ hydraulink for 3 Point Toplink #6
RamTruckMan,
When writing a previous post I was thinking about pump operated hydro top link.
The HydrauLink is a different and probably a good thing. I say 'probably' just because I've never had it. But the idea seems to be very good.
/ hydraulink for 3 Point Toplink #7
The real hydraulic top link is about the same money as the hydraulink. That seemed to be the consensus of the contributors to the previous thread. But it is a step up from the manually adjustable top link.
/ hydraulink for 3 Point Toplink #8
Alright, for those that have a hydraulic top link (not this one) does the ram move at all?? I just don't see that as a good (or even acceptable).
/ hydraulink for 3 Point Toplink #9
The ram doesn't move unless they control valve is activated to send oil to it.
(if that is your question).
/ hydraulink for 3 Point Toplink #10
The ram doesn't move unless they control valve is activated to send oil to it. (if that is your question).
Correct... BTW, I went to the link above... LOTS of reading, one of the first posts I read (post #81) mentioned "rigid top link" for HTL... and that's what I wanted to hear.
/ hydraulink for 3 Point Toplink #11
Correct... BTW, I went to the link above... LOTS of reading, one of the first posts mentioned "rigid top link"... and that's what I wanted to hear.
We don't need to go down this road again, but the ram does indeed move when locked in place. There is air over hydraulic fluid and I believe that the ram moves somewhere between 1/2" and 1". Watch the video and see for yourself.
My guess would be that not to many people from TBN bought them, they had been advertising on TBN and I don't think that they are at this time.
Lots of entertainment in that thread. :laughing:
/ hydraulink for 3 Point Toplink #12
Sorry MVR, and everyone... I meant the the True Hydraulic Top Link was ridged... (that was a heck of a thread!) When I first saw it advertised and saw the movement... I didn't think it would work... (I corrected my post above to reflex that).
/ hydraulink for 3 Point Toplink #13
When that thread was active I Only had the screw type manual TL, now I have 2 tractors both with real hydraulic TL and 1 with HSL (thanks MVR) and boy what a treat, would hate to go back.
As to the movement question, I don't see any except it does pivot with the 3pt and on my flail I mount using the slot ( per Island Tractor) which allows the mower to follow ground contour.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
JOHN DEERE CART (A62131)
JOHN DEERE CART...
2021 Hitachi ZW150 Wheel Loader (A61166)
2021 Hitachi ZW150...
2018 John Deere 8345R MFWD Tractor (A63109)
2018 John Deere...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2022 John Deere 317G Compact Track Loader Skid Steer (A61567)
2022 John Deere...
