Replcement Engine for Troy-Built Horse
/ Replcement Engine for Troy-Built Horse #21
The Honda clearly goes best with the original troy bilt red.
did it bolt right up with no problems?
/ Replcement Engine for Troy-Built Horse #22
yes . it's bolts right up . save the old bolts and shaft key and pop it on i even used the old shims . the only thing you can't use is the shaft bolt i believe it was 5/16 instead of the tecumesh 3/8 . i think it took about 30 minutes to bolt the new motor on and have it running .
briggs makes a troy bilt red motor also but it is more hp and more money .
i am really happy with the honda .
/ Replcement Engine for Troy-Built Horse #23
here are a couple of photos . in the first photo you can see the disconnected low oil cut off wire with the orange electric tape .
MrTooth,
Just curious.... is that unit an older one such as mine.... c. 1978? (orig. 7 horse Kohler)
Tnx..RUT
/ Replcement Engine for Troy-Built Horse #24
MrTooth,
Tnx..RUT
i believe it's from the mid 1980's but i am not sure . the original motor was a hh-60 tecumseh if that helps date the tiller . i believe it's considered a 4 speed with forward , reverse , high , and low . hope this helps.
I want to thank everyone of you who responded to my original question about my TroyBilt engine replacement. I completed my exchange with the 6.5 HP Harbor Freight Greyhound version of a Honda clone.
I had to also replace the 4 engine mounting bolts with a 5/16 X 1 - 24 thread because the original Tecumseh had narrow threads. The 5/16 X 1 1/2 - 24 thread bolt for the end of the shaft that secures the drive pulley was also replaced because the original bolt has narrow threads.
If you are thinking about trying an engine replacement I may share some hints:
1. I removed the bolt to the rear of the drive pulleys and reversing disk. This gave me access to the inside of the pulley as it fits onto the engine drive shaft. I sprayed PB Blaster in the area and left it sit for 36 hours. It may have helped.
2. Slide the belts off the pulley and slide the dual pulley away from the frame. It will give better access to the 4 mounting bolts.
3. If you remove the bolts at 2, 5 and 7 o団lock positions (looking from the handlebar) you will be able to twist the old engine a bit to give better access for removing the final bolt located at the 11 o団lock position. If the belts are out of the way a ス socket on the end of a wobble extension will work. A ス ratchet type wrench may also be helpful.
4. When I began the reinstall I used my floor jack with a plywood platform to align the drive shaft through the frame so I could start the first engine mounting bolt (11 o団lock) first.
5. My original engine had 4 shim washers on the shaft to align the drive pulleys. I used 2 washers, a total of 1/8 on the new drive shaft to get the proper alignment with the drive pulleys on new engine. I haven稚 reconnected the throttle cable yet.
6. My best wishes to everyone else wanting to do their own exchange. If this information has been helpful to anyone else, I am rewarded. Others have helped me so much in the past. This forum has been extremely helpful to me. I check it often and try to assist other when possible.
I tried to share a photo of the drive pulleys pushed to the rear. You may also be able to see one of the holes where a bolt was already removed. Look closely at the photo of the socket and bolt. A small piece of paper towel was used to wedge the bolt tight so it didn稚 escape during the reinstall.
/ Replcement Engine for Troy-Built Horse #26
i'm curious why you didn't just remove the 1/2 inch rods on each side, an set the motor and mount off to the side to swap engines? i admit i have never done it, but i thought that was what they were for??
heehaw
/ Replcement Engine for Troy-Built Horse #27
Haw.....thats the easiest way. I did it to (2) tillers, both new engines installed and was done in about 2 1/2 hours.
Craig
/ Replcement Engine for Troy-Built Horse #28
Just bought that identical engine. Ready to put it in but have too much play on the transmission shaft yet. Not sure if shim another 1/4 + inch or bearings need replacement. Suggestions welcome.
What did you do with the engine for throttle cable or more importantly engine shut off. I wrecked my old one crashing into something and destroying the tecumsey flywheel. (those parts available now!)
How do you disconnect or override the oil shut off?
Your knowledge will help. I did have a manual and took off the whole engine mount, though.
/ Replcement Engine for Troy-Built Horse #29
I included a photo of the low oil disconnect wire ( this is from the Honda motor ) . Hope this helps.
/ Replcement Engine for Troy-Built Horse #30
I repowered with a B&S Inotek 6.5 hp. Small Engine Warehouse had a bunch of NOS engines with some external rust. Had a starter, but no generator/alternator. Had to grind a bit off of the engine mounting piece to clear that, but not significant (no harm). I might someday hoop up the factory battery and switch set up (no big deal to hook up a small battery charger).
I left the throttle off. And the kill switch. Just use the controls on the engine. Works well. Just wish I had thought to get a larger engine (I am at altitude).
Originally it was the HH60 Tecumseh engine. The B&S is a much nicer engine, as it should be (being a decades newer design).
/ Replcement Engine for Troy-Built Horse #32
Seems to get pretty good reviews for being a brand "X" machine. It's anybody's guess how it'll stand up in the long run, but for the cost, who cares? :)
/ Replcement Engine for Troy-Built Horse #33
As I said in a previous post I used that engine on (2) tillers I had handed down to me in the family. Those Greyhound Engines are the easiest starting small engines I have ever used.
I tilled up a small area before putting them both away for the winter and I can tell you they have all the power the tiller needs. As for the long haul, if I get a few years out of each one they will have paid for themselves. I paid $99.00 each for them when they had them on sale. Can't beat that!
Craig
/ Replcement Engine for Troy-Built Horse #34
sure wish i could catch one of those sales....i need to repower two tillers...
heehaw
/ Replcement Engine for Troy-Built Horse #36
can't get to Little Rock before this runs out, but that is a heck of a deal...may try to order one online...depending on shipping charges..
thanks
heehaw
/ Replcement Engine for Troy-Built Horse #38
sounds like a good repower.i have an old troy horse with a 7 hp kohler and it starts on 1 pull.
/ Replcement Engine for Troy-Built Horse #39
When the Greyhound engines are in the flyer they are sometimes listed for $99 you can use the 20% off coupon too at the store. Got mine for $79 a few months ago. I am pretty sure they are in the flyer for $109 and there is a 25% off coupon for "Thursday only" guess they want Thanksgiving Day business
/ Replcement Engine for Troy-Built Horse #40
If you are thinking of a run to HF, before you go, run a Google search on "Harbor Freight 20% coupon" and you will find online links to ones you can print and bring with you. They always have one running, as far as I can tell.
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2018 INTERNATIONAL...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
