6010 vs 6011
/ 6010 vs 6011 #31
Rjmack,go get you a copy of the structual welding code aws d1.1,it says to only use a low hi welding process,,,if you wasn't welding to that code than you wouldn't need to,and don't believe that a 6010 weld would be less ductile than a 7018,less tensile strength, but not less ductile,,just looked up something along those lines in an old welding book I got,,according to it and aws A5.1 from which they got it from,the elongation standards,which is measured by a tensile test[how far it streaches before it breaks],is both 22 percent in a 2 inch area measured after section is pulled till it breaks,in other words both have to meet same standards as far as ductility.
/ 6010 vs 6011 #35
Rjmack,being the man I am:laughing: I actually went and looked in an old d1.1,and it will let you use 6010 in a few instances,most every thing in the book though calls for lo/hi,and in all cases I've ever been around as far as structual,its lo/hi,,might be cases of welding structual pipe where root could be put in with a non lo/hi....so,,,,,:D
/ 6010 vs 6011 #36
Thats the way all mine used to look back in the day and I didn't roll it either:laughing:
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60352)
2018 Freightliner...
KUBOTA KX057-4 EXCAVATOR (A59823)
KUBOTA KX057-4...
Topsoil Trommel (A57453)
Topsoil Trommel...
John Deere Z994R (A60462)
John Deere Z994R...
206320 (A57192)
206320 (A57192)
