Oil change on cab tractor
/ Oil change on cab tractor #1
KB9UDE
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
I am getting ready to do the first service on my 4720 cab and it looks like I will have to remove the loader to get in and refill the oil?? Does this sound right?? I think it is a tighter area to work than my open station was.
/ Oil change on cab tractor #2
I have to drop the loader to change to oil too..that applies to my old Deere 670, 790 and current 4400. Can't pull the side panels with th loader installed.
/ Oil change on cab tractor #3
Changed oil on my cab 3520 awhile back. No problem with the loader on, just needed a funnel with a long neck. No fuss, no mess.
/ Oil change on cab tractor #4
On my 855 it certainly is easier to do with the loader off. Much better access to all sides of the engine etc. I have done it without removal though.
/ Oil change on cab tractor #5
i have no problems removing the side panels on my 4310 with the loader in place
/ Oil change on cab tractor #6
I can remove the side panels on my 4010 with the FEL on. Last coolant change though, I proped the loader up on a 4' piece of 2 by, just to get the arms out of my way.
I found out that my oil (Pela marketed by DR) extractor will remove ALL the oil from the crankcase. So, in future oil changes, I'm not going underneath the tractor to take that drain plug out. I extracted this last oil change and removed the drain plug. NOTHING came out. This is better than it worked even on my Tacoma engine.
Ralph
/ Oil change on cab tractor #7
4120 w/ 400x loader here - no cab, but I do not have to remove the loader to change the oil. I did use a transmission funnel to make it a little easier to pour quickly though. The filter, dipstick and filler cap all are in close proximity on the left side, don't even have to lift the hood. I would expect your 4720 to be identical.
/ Oil change on cab tractor #8
I'm kinda clutzy and it's real easy for me to spread a few ounces of oil - here and there - when I refill the crankcase... :ashamed:
So, I always propped the FEL up with my JD 970 and I drop in the hyd cylinder block on my 110 when I do the service.
Do you have an engine hoist or overhead chain hoist that you could use as a "safety check" on your loader?
AKfish
I need to go look at an open station tractor again but it just seems like with the cab its a tighter fit to get into the oil fill location. I have thought about poping to loader off but then I see how close it is to the front glass and I ask myself "do I really want to take this loader off???" :eek:
/ Oil change on cab tractor #10
You answered the question I have been asking myself while following this thread. Since the loaders are so easy to remove, I didn't know why anyone would not bother to just do that. I remember now the concerns I have heard about the closeness to the cab front glass.
/ Oil change on cab tractor #11
Been there broke that, shattered the left lower glass with the loader arm pop off.
http://www.tractorbynet.com/forums/john-deere-owning-operating/126061-glass-installation-help.html
I foolishly removed my loader while my unit was on a uneven surface and paid the price. On the upside, I know how to install a window now! LOL!
/ Oil change on cab tractor #12
I changed the oil on the 3720 OS without removing the FEL. Just used a funnel with a long spout. But yes, the 4x20 series with cabs are very tight with servicing. I would remove the FEL on level ground and get the job done. Think, you have a good amount of control when installing the FEL especially with a HST tractor and at low throttle run the hydraulics so it will slowly reattach onto the machine.
213089 (A64276)
213089 (A64276)
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
