need some advice
/ need some advice #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I ran a brand new chain for 1 day and hit a nail today. Do I have to take all of the teeth down to the smallest tooth? I don't know what you call these but I obviously built it wrong. It is 3 X's perpendicular to some straight pieces of wood to cut firewood on. Is there a way to build this apparatus so no nails are in the way of the chain?
/ need some advice #2
No, chainsaw chains are not like a saw blade where balance is important. Sharpen each until they are back to good shape. I believe if you even had a couple broken right off it would not really matter. Sound like you should buy the second chain, that way on days like this you just slip the other chain on and keep working. Later sharpen the, now old one, and your ready for the next nail!:laughing:
:thumbsup:
/ need some advice #3
I agree with Spudhauler, the teeth don't all have to be the same, just get them all sharp. By the time you get all the teeth sharpened, you will probably have to lower your rakers.
If I'm picturing your buck correctly, can you run stringers on the lower legs of the "X"s, to keep the nails below the cut?
You should be bucking the part of the log that extends past your last "X", so there shouldn't be any nails in the path of the cut?
/ need some advice
how do I identify and correctly lower the "rakers" ?
/ need some advice #5
Logan:
Please find someone experienced with chainsaws to show you how, or take your saw to a shop for sharpening. If your rakers are too high, your saw will cut poorly or not at all. If you file them too low, the saw will be "grabby" and is likely to "kickback", causing serious injury when you cut with it.
You need to have someone else sharpen it or find someone to teach you, for your own safety.
There are many different sharpening guides available to make it easier to hand file chainsaw chains.
/ need some advice #7
There's probably a dozen good videos on you tube to show how to sharpen a chain.
I'd second the advice of getting a second chain.
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
