Opinions, Opinions
/ Opinions, Opinions #1
NCMau
Gold Member
NC
MF 202/Ford 8N
My Massey 202 (industrial 35) tractor has a loader which is powered via a selector valve , by the onboard pump (I believe 4gpm). The loader is not as fast as it could be with an external pump, but it is adequate for my occasional usage.
I would like to add an hydraulic powered 30" deck as a side loader attachment to be able to trim several hundred feet of tree hedges of wood trails.
I have an Eaton motor P/N 101 1704 009 which, according to the specs, is rated at 10 gpm/1021 rpm. Since this attachment would be used probably only once a year, I would rather not install an auxiliary pump.
So my questions are: can I get by not using an auxiliary pump, and what do I need to control the deck motor? Also, would I need the full 10 gpm motor capacity to run the deck? The deck working load is actual minimal. It consist only of thin branches.
/ Opinions, Opinions #2
I believe your system has very low pressure also...I don't think you are going to get any usable work out of that motor hooked to your tractor.
Kennyd,
this is the answer I was expecting, but I thought I ask anyway.
I need this deck attachment, so I am going to go with a PTO pump. I suppose I need some kind of variable speed control valve. I checked NH, but I am not sure of the choices.
What is an acceptable way to connect the motor to the loader control valve? A "T" before the valve input?
I welcome a suggestion. Thanks.
/ Opinions, Opinions #4
You want want is called a "motor spool valve". Here is one at the SC: https://www.surpluscenter.com/item.asp?item=9-6767&catname=hydraulic
Not sure I understand this question? You will have to build a separate system, including the motor, pump, valve, tank, filter and hoses. There will be no "connection" to the loader valve.
What kind of budget are you thinking? It not gonna be cheap.
/ Opinions, Opinions #5
I think by the comment that the loader is slow that he would also run the loader off the auxiliary pump. The first thing he needs to do is determine if the motor he has is going to be adequate to power a 30" mower deck. I have no Eaton info, but by the 101 prefix I think that may be in the 5 to 9 HP range so that may be marginal. What is the RPM limit for that motor? I'm thinking 1070 @ 10GPM is going to be too slow? More GPM will equal more RPM. How fast should a 30" blade turn? Twice that?
No tees on the pressure "in" side of valves. Hydraulic flow will go the route of least resistance so nothing will work. The loader valve would need to be power beyond to the valve to control the mower motor. Like Kenny said, this won't be cheap to build.
Kim
Thank you Kenny and Kim.
Let me clarify my comments. I do have in mind to add a PTO pump, which I already have on hand.
The deck motor speed is 1021 rpm, 10 gpm and torque is 497. So with these figures, if I did my math right, the motor should develop about 8HP, which would be adequate for my purpose. The speed of 1021 rpm maybe questionable but I think it would be satisfactory for light work.
The main question was how to control this motor. I checked the link at Surplus Center, but how this valve motor work? Do I activate the lever to run the motor (hands off) than activated it again to stop it?
I have a spare control valve for my hydraulic splitter. Could I use this valve for this project?
... Or, if I am not over extending my welcome with another question. I also have a 4 spool control valve on hand that I could use instead of the existing loader 2 spool valve. Can I use one of the 4 spool section to control the deck motor? (Possibly with a modification?)
Again thank you for your patience. Just trying to increase my limited hydraulic knowledge and use parts that I have.
/ Opinions, Opinions #7
You need a motor spool valve. A regular "loader or log splitter" valve will not allow a motor to coast to a stop and you risk damaging or destroying your motor from the sudden stop, especially with a inertia load like a 30" blade . I didn't look at the valve Kenny linked, but most valves would have detents that allow you to push the lever to start the motor and it would stay in that position until you return it to neutral. If you could replace one spool in your 4 spool valve with a "motor" spool you could use it. What do you plan to use for an oil reservoir? You will need at least 10 gallons, and more is better to avoid aireation and heating problems.
Kim
/ Opinions, Opinions #8
Attached are photos of a rig I built several years ago. It is a Prince 11gpm pto pump powering a Char-Lynn 4.9cu in/rev motor which drives a Bush Hog 48" Squealer rotary cutter mounted to the FEL of a Kubota L4330. I wanted to control the cutter with the pto clutch, just as if it had been connected by a driveshaft to the pto. This saved having to mount a separate motor valve at the operator's station with all the lines, plumbing etc. That spot is already pretty crowded as the third picture shows. So I ran the pump/reservoir lines directly to the motor. To address the overunning problem Kim mentions, I inserted a check valve into the circuit at the motor. The check valve is shown in the second picture. The only disadvantage is that the motor can't be reversed, but neither could the mower when driven directly from the pto.
Kim
Thanks for clearing things up, Kim. Yes, I plan to install a reservoir back of the seat.
I already have a 5 gl tank which would fit nicely, but I guess I'll be looking for a bigger one.
I think I misunderstood your statement about the 4 spool valve. How can you replace one spool for a motor application? Do you mean an internal modification or just add an external motor valve? I believe this valve came originally from a BH.
I like the idea of the check valve. It would work for my project because there is no need to reverse the motor. Thanks
/ Opinions, Opinions #11
How can you replace one spool for a motor application? Do you mean an internal modification or just add an external motor valve? I believe this valve came originally from a BH.[/QUOTE]
If it is a sectional valve (bolt together sections), a motor spool valve could be added or substituted. If it is not sectional, it might be possible to just replace the sliding spool inside the valve body with a motor spool. You would have to contact the manufacturer or a shop that deals with that brand of valve.
Not sure I understand the purpose of the check valve Farmerford mentions. If the PTO does not stop too abruptly when disengaged, that would work OK.
Kim
/ Opinions, Opinions #12
Great explanations Kim:thumbsup:
Kim
You did a beautiful and professional job in building this project. I am trying to figure out why you went through such an elaborate and expensive scheme, when you could have just hooked up the cutter to tractor PTO.
I am just curious and trying to learn something.
/ Opinions, Opinions #15
Kim:
The check valve allows the motor to freewheel when there is no hydraulic fluid flowing from the pump. The CV has a very low cracking pressure (5psi if I recall). The pto pump quickly stops when I disengage the pto clutch, even it the pto is turning 540rpm. Therefore, there is no pressure from the pump forcing hydraulic fluid to the motor. Indeed, the gear type pump blocks any fluid flow from the tank, even though a vacuum at the motor tries to draw fluid.
A slight vacuum (5 psi I think) opens the check valve to allow the fluid that is being exhausted from the still spinning motor to flow back into the motor inlet port, which allows the motor to keep turning with very little fluid resistance. In fact, if I suddenly stop the pto at 540 rpm, the hydraulic motor and cutter drive train (90 deg gear box, blade holder, stump jumper, and blades) take a minute or more to spin down.
As you (Kim) pointed out, if the spool valve is a regular four way, three position directional control valve (whether monoblock or sectional) for double acting cylinders in which the work ports are blocked in neutral to keep the cylinder from drifting (rather than open to tank like the motor spool), then when the valve is closed the motor has neither a source for new fluid nor a place to send the exhaust fluid since the work ports are blocked at the valve. The check valve across the motor ports works fine in this situation.
/ Opinions, Opinions #16
Got it. I guess I should have looked at your pictures! Pretty clever.
Kim
/ Opinions, Opinions #17
There was also a front mounted pump that went on the front of the crankshaft to run the loader (Dads industrial 35 had that). I think it was a 7-10GPM pump (3/4" suction line, 3/8" or 1/2" pressure line connected to a tank built into the RH loader frame). If you have the hole through the front axle I might look into getting the right shaft and pump to switch to that. It makes the loader MUCH more fun to use.
Aaron Z
Aaron Z
Thanks for the tip. I have the option of installing a front pump, but since I already have a PTO pump, I am going to stick with what I have. My loader frame does not have the ports and that would be another pain to modify. In addition, looking at the frame, I am not sure It would hold more than 5 gl. I would need at least 10 gl. for the additional hydraulics I want to install.
Maury
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2015 Hyundai Elantra Passenger Car, VIN # 5NPDH4AE7FH560718 (A64557)
2015 Hyundai...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
