Breaking Up Ground Will This Implement Work For Me?
/ Breaking Up Ground Will This Implement Work For Me? #1
Brandon1107
Member
South Texas
Kubota M8540
I got this implement thrown in with an old David Brown tractor that I bought. Is it a chisel plow? I want to use it to break up the soil before I disk looking for deep penetration to break up compaction for food plots, kleingrass, and buffel grass. I think I will need to remove the sweeps. It has 7 shanks and I will pull it with my M8540. I am going to try it first before I put the money for a hydraulic cylinder, come-along works well. It needs some welding done on it as well but I have plenty of friends that are excellent welders. Will the shanks spring back if I hit roots, will the tractor stall, or will something break? I guess that's a good start on questions.
Thanks,
Brandon
/ Breaking Up Ground Will This Implement Work For Me? #2
A picture would be great. Most chisels have the C type shanks with spring built in the shank. Here is a picture if a 3 point 5 shank like I am talking about. Ken Sweet
Don't know why pictures did not show up I attached with iphone web app. :confused: Trying from pc now.
/ Breaking Up Ground Will This Implement Work For Me? #4
You have spring built in to your shanks, I would take off the wide sweeps and put on narrow points that are approx as wide as the shank. This will let you penetrate the soil deeper. For about $35 you can get a ratchet jack at TSC to eliminate the need for a hydraulic cylinder. You will do fine. Ken Sweet
Thanks Ken,
Do I need to raise this when turning corners like when discing? That was my reasoning for the hydraulic cylinder. I have an old ratchet from a rotary cutter in the shop that I can use if I don't need to raise on turns.
Any idea what this is called and who made it?
Thanks for the tip.
/ Breaking Up Ground Will This Implement Work For Me? #6
Thanks Ken,
Thanks for the tip.
I would think If you are running deep, you may have to raise on corners. Probably not if you are going 4-6 inches and making long turns on the corners. I don't recognize the mfgr. I would think it would be a chisel plow on transport wheels? Ken Sweet
/ Breaking Up Ground Will This Implement Work For Me? #7
There was a much larger version of that working in our fields the other day being pulled by a JD 8000 Series. Most I have seen in use around here have the sweeps, the one we used when farming had the narrow points as mentioned by Ken.
/ Breaking Up Ground Will This Implement Work For Me? #8
Around here we call that a "spring tooth harrow". It's the right tool for breaking up soil to maybe 6 to 8 inches deep. And then you can go back and sink it deeper. I've sunk them to the frame once the soil is broken good. If the soil moisture is right, the vibration of the spring teeth will almost powder the topsoil. They do have a bit of problem with rocks and also pick up a lot of trash.
rScotty
/ Breaking Up Ground Will This Implement Work For Me? #9
You have what you need for your objective. I've used exactly the same type of chisel plow for the purpose of breaking up ground, disking, then planting Klein seed.
You want to use the narrow chisel points, not sweeps.
You have a tractor large enough to pull it....very well...and it takes a LOT of horsepower.
A hydraulic cylinder would be WELL worth using. You WILL need to lift it out of the ground to make any kind of a tight turn...and if you don't, it puts lots of strain on many components.
With your tractor, if you hit a nearly immovable root or rock, you will break a tine. I have with much less horsepower. Nevertheless, it is what you need. With a hydraulic cylinder, you can EASILY set and change the depth of the chisel. If you hang up, you can raise it, back up a tad, get unhung, pull forward a tad, reapply the plow to the ground and go on.
Without a hydraulic cylinder, you will be there for 30 minutes racheting up and down and messing with stuff.
Cost of cylinder and hoses should be about $150 or less. Have your friends weld up everything first....
This is a wonderful tool. You will be very glad you have it after you see what it does. First pass is a little dull... looks kinda like scratches in the ground. Next make a pass at about 30 degrees angle from the first...you will be amazed at how it turns up the ground. A third pass at yet a different angle will complete the work....
Thanks John very helpful and thorough. You are an asset to the forum and its members!
/ Breaking Up Ground Will This Implement Work For Me? #11
Thanks, Brandon, each of us have various experiences and expertise.... glad some of mine can help you.
By the way.... glad to have you here on TBN.:)
Now is exactly the time of year to begin preparing the seedbed for spring Klein planting. Your objective is to be planting into DUST, no clods. I recommend 3 passes with the chisel, sufficient to really break up the soil reasonably deep, 10 to 12 inches and then disk once, maybe twice...depends on how the soil responds, moisture content, how your equipment works, etc. If you have perhaps a drag harrow or something to put a final smooth finish on the ground, that is ideal. The seed is extremely fine, kinda like medium ground pepper.
Properly planted, the seed is dropped on the surface of the ground then heavy rollers press it into the soil and assure the seed is in good soil contact. Planting depth should be 1/4 inch, no deeper than 1/2 inch. A Brillion seeder is the preferred seeder. Hope you have located a seeder for Klein... typically the soil conservation service knows where one is..often has one you can rent for a day or two very reasonably.
I should mention how the chisel works... when pulling it there is a speed which you will find by trial and error which works best. At this speed, there is a balance between chisel depth, tractor horsepower, forward speed and ground conditions. What you want is for the tines to be in a constant vibrating action.... meaning that a particular tine will catch a little bit on the ground and bend backwards until sufficient force is exerted to where it springs forward as the ground gives way and thus sends a shock wave thru the immediate soil area and fractures it. It won't take you long in practice to get the hang of it, knowing what to look for.
Enjoy your tool...I think it's a dandy....be prepared to spend something like $50 to $80 for a broken tine, at least that's what I recall mine cost.
OK after plowing through hundreds of pictures on the web I have deduced the chisel is a Graham Hoeme S. Here is a picture of one in much better shape. Does anyone have any experience with these?
http://www.google.com/url?sa=t&sour...s9yqDg&usg=AFQjCNGNUYfPYNL0YvzN1UshinzYNegFOQ
Turns out these were considered to be one of the first ever chisel plows! The above link is pretty interesting reading and talks about how the chisel plow helped to end the dustbowl.
2009 Volkswagon Jetta Sedan (A64557)
2009 Volkswagon...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2004 Chevrolet Trail Blazer 4x4 SUV (A64557)
2004 Chevrolet...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2016 Isuzu NRR Elgin Broom Badger Sweeper Truck (A64556)
2016 Isuzu NRR...
