Grading Clean up and grade (?) a wooded lot with Loads-A-Rocks . . .
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #21
The rye didn't take... the turkeys cleaned it up like a starving man at a buffet. When they stumped the field a layer of topsoil came iwth it. Even before then though, the ground was so barren that I am just starting to see earthworms.
Try broadcast barley over loose soil, then dragging it to incorporate and cover the seed.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #22
We have relatively good soil in my neighborhood, a few rocks, my property was part of a dairy farm and most of the bigger rocks were picked years ago. There is a great deal of land nearby that are glacial moraine and and areas where successive glacial events packed old moraine into a pavement like structure. In those areas trying to garden in the native soil is nearly impossible. Pick out enough rock to get clean dirt results in about an inch of soil for every foot deep of rocks!
I have used annual rye for years as a cover crop, I spread the seed then run the tiller through the top inch of soil to hide it from the birds. For the last couple of years we have been using fava beans as well for cover crop. They fix a lot of nitrogen and the stems break down quickly when turned under.
This year with a late wet spring the cover crops were about 3 feet tall, I had to mow them down with the lawn tractor before turning them under.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #23
I don't know the exact composition of the dirt in the Marbletown area but I would be surprised if a rock bucket would be
worthwhile trying to use.
It would be expensive but once the trees are removed a dozer with rippers can run through it and loosen the rocks up,
and break up the soil a bit then when it gets try you could try a skeleton rock bucket with large spacing between the tines
to get the large rock.
Screening much of the dirt in New York requires a powered screen to break up all the clods of dirt and separate the rocks.
If you screen over 3 " you might be successful but it will take a high powered screen with some clod breakers.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #24
Hey there Joe a 99-- having read the last 21 posts I am wondering if you are "barking up the wrong tree"... so to speak. Extremely rocky ground in a woods is going to be a major challenge in terms of a garden.
We don't have a lot of info to go on. Need more I think in order to 'pontificate effectively.' Picture maybe ? Any chance of buying an acre or maybe just a strip adjacent to you with enough space for the garden? That might be a tradeoff against the cost of clearing. It takes generations to convert really rocky woods to a garden spot and, even then, you may end up with shade that defeats the purpose.
I'm thinking you can hire someone to clear enough space for an outbuilding (some guy nearby with a small dozer and/or an excavator) in less than a day's time. That would leave you with a more practical task of moving a few rocks around, sawing up the remains of the trees, etc. Then, as others said, have a layer of suitable filler put in for the building site. Who knows, if it is that rocky the existing ground left after it is cleared might be suitable for laying concrete? You have a "pole barn" in mind?
Seems to me if you can get a strip of ground for the garden that is a game changer.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #25
Might not be a good title or the right forum, but, got about between 1, 2 acres of treed land behind the house. Soild is VERY rocky with stones of all sizes, some pretty hefty. Trees of all sizes and varieties.
The intent is to be able to put up an out building for work and storage and, maybe, make an area suitable for a small food garden plot.
Already been cutting down some of the saplings on up to 8" or so and cutting them stove length. I've had some old timers tell me to just drop 'm and leave 'm till the leaves brown up, then cut as they would then be ready to burn in the fall. That's a tale for another day.
I found digging out roots with a normal bucket to be almost a fool's errand. It's only a B21 after all. But, I did some internet digging and found BXpanded that makes a "ripper tooth" for about $300. Finally got around to using it and, after a bit of practice find it works every bit as well as the maker and the comments claim. Almost fun now.
Gotta be careful as a lot of the trees are very close and no doubt have interlocked roots. But that's not really why I'm here today.
The unpleasant surprise has been the far greater number of rocks than imagined. The bigger ones, say over a foot wide, I just try to move off to the side for now. A bit dicey with the tooth as I am fearful of bending it if not careless.
Guess the question really comes down to ways to clear a lot of the smaller stuff out? Not to "topsoil" grade, but reasonable to where you could stick in a spade or shovel and not hit a rock every time.
I've seen static screen units where you dump on top of a slanted screen and let gravity be your friend. Even those are very pricey, to me. Tractor has a 4 in 1 bucket and I was thinking of making a temporary screen out of rebar I have lying around, to fit the bucket, allowing it to scoop then open wide sift and dump. Not thought that out yet, may not by practical given the geometry(s) involved.
So, looking for comments and suggestions.
I have the problem of rock and clay soil here in the Hill Country of Texas. To make my garden area l dug down about a foot with my backhoe which wasn't easy and using some scrape steel roofing made a 2 ft wall around it attached to 4x4 post. I then had 2 truckloads of grow mulch dumped in. The whole thing cost less than $1000 and have been enjoying fresh vegetables ever since. Wall keeps the critters out too.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #26
Raised beds might be best, but I have always been put off by wooden sides. Was wondering about putting some of these rocks and boulders to use in that way.
Wood sides (4x4 or 4x6), old post and beams, or RR ties can all be used so long as you don’t allow the dirt to come into contact with your soil. You don’t want those pressure treated chemicals or that creosote killing your plants or you for that matter.
I mentation this because you can easily cover the face of your beds with anything you want - metal siding, bricks, rocks, or even the stucco stone.
If that doesn’t do it for you, I’ve built “raised” beds for people using tractor tires stacked on top of each other with metal fence “T” posts driven into the ground to keep the tires from shifting. Holes were drilled into the tires and the posts went through them. We then ran wire between the posts and in one area it went between two beds. The wire was used for beans and other climbing veggies.
The other method I have done for customers in the past was using cement blocks. In similar fashion “T” posts were used in the corners and rebar was used in other areas. Some of which were extra long pieces to not only drive into the ground, but to help reenforce the concrete mix and to act as an area by which wire/rope could be tied off. For that project we built four of the beds in a perfect rectangle shape to accommodate the owners later adding a “greenhouse” to their garden. Which was basically long pieces of pvc pipe running from one corner (over top the “T” post) and then curved to the opposite corners post. I think we ran 8 or 10 pieces of PVC and then had two 10’ sections that were used to roll the plastic “greenhouse” cover over the pvc and two more pieces on the opposite side. Doing it that way helped to hold down the plastic as well as allowing both sides to be rolled up to a whatever designated height they chose. This allowed better airflow and/or protected based off the wind direction and earths location in relation to the sun.
Hopefully one of these ideas helps to inspire you or someone else who might read this. Mind you…not one of these projects were done in the city. So don’t feel like you’re losing any of your country ways doing things like this. You are actually better off with raised beds, because you can better regulate your soils pH, temps and chemistry. It’s also a heck of a lot easier to water and keep clean/free of weeds. Best regards…
-adam
-adam
Food for thought. Gotta factor in some kind of robust fencing as well. Around here the deer and other critters can take a garden down to the roots overnight. They ain't shy at all.
At this point I'll be planning for next year, looks like.
I doubt 2 ft will keep the deer out, but, gives me a potential use for those old steel sheds I need to tear down. Might be too thin for the job.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #29
Joea99,
I made sides for raised beds from plastic wood that gets sold for decking. Used the corrosion rated deck screws ( ceramic coating? ) to fasten ot all together. Never rots out and doesn't leach chemicals into garden soil. Had beds in place for 20+ years until we moved and then I disassembled them and took the plastic boards to new house. The only issue is the plastic wood is not as stiff as real lumber so I supported the sides along span every 4-5 feet. Split a 6 inch board in half and screwed halves together and then cut a point onto it and drove it into ground next to raised bed and screwed raised bed side to the new post.
Use fencing taller than 5 feet because white tail deer can jump over 5 feet from a stand still. They love brussel sprouts and wouldn't leave garden until I got with 20 feet.
   / Clean up and grade (?) a wooded lot with Loads-A-Rocks . . . #30
I had to build a 8’ deer fence around my garden and orchard.
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
2025 GPS GTT7167K 16ft T/A Utility Trailer (A56859)
2025 GPS GTT7167K...
(2) 5' TRAILER RAMPS (A58375)
(2) 5' TRAILER...
VIDEO LINKS FOR ALL LOTS W/ VIDEOS (A59213)
VIDEO LINKS FOR...
LINCOLN ELECTRIC GENERATOR (A58216)
LINCOLN ELECTRIC...
