Sand Blaster clogging - need help
/ Sand Blaster clogging - need help #11
I gave up on the cheap pressurized thank type, now use a Coleman siphon gun ($20), just stick the tube in a bucket of abrasive & blast away!
/ Sand Blaster clogging - need help #12
I have a 80lb. capacity Bad BOY name brand blaster I bought off Ebay. I had trouble with it here in the south using sand, because of moisture. I called them and they recommended Black Beauty such as what you got. I purchased it from TSC. Northern Tool also carries it. It worked great. By the time the tank ran out, I was ready for a break. LOL I didnt know till I went back to get more that it comes in different size particles. The second time I went to get more, I just grabbed some bags and left. The particles kept clogging the gun. Then I noticed the bags had diff. numbers from what was on the first bags I had bought. I carried them back and traded them for what I had the 1st time Problem solved. The number that I found that worked best was 40/80. It will be stamped on the bag. I hope this helps you. zman :thumbsup:
Thanks everyone for the information
I ended up getting sand from a local block place that is a white sand, fine texture and it works GREAT! Had to be the sand. The black diamond is dry as dry can be but just clogs the hose, gun, valve, everything. The white stuff went right through no problems at all. Shot about 80lbs tonight and never had to stop. I was impressed.
Anyway, for the others I would look for a white sand in a fine cut and see if that works better for you.
Good luck and thank you to everyone that had ideas and thoughts - that is what makes this site so great!
/ Sand Blaster clogging - need help #14
The local block place will not sell me sand that is used for plastering if you mention sandblasting. Creates lung problems. Does a wonderful job using a pressure type forced air mask like painters use. Everything is a trade off - but you should be aware that silica sand is considered dangerous.
/ Sand Blaster clogging - need help #15
may work now but soon as it warms back up the humidity will make it clog again probably. maybe not. good luck and keep on blasting. zman :thumbsup:
/ Sand Blaster clogging - need help #16
1) look up "Silicosis". Take precautions as in an EXcellent mask or supplied air set up. The black stuff is carbon residue from power plants and is not near as harmful as sand.
2) the black stuff cuts rust / paint much better than the white sand. But, the grains are larger, so you need a larger opening.
3) as others stated, start by closing the "out" line from the bottom of the tank and keep the bypass air line open fully 100%. Start blowing air and slowly open the sand valve. Go 1/4 turn at a time and see how it does, less is more with sand blasting (except for air where more is not enough and too much is just barely enough).
4) when you shut down, turn off the sand valve then stop the dead man.
/ Sand Blaster clogging - need help #17
My experiences with the black diamond stuff and my hf blaster is the shape of the black diamond stuff is why it clogs. If you look at it some of it is shaped like little rods and if they get turned in the nozzle they wedge in and the rest just builds up against it. If you go up to (I think 80 grit) in the black diamond brand it should work pretty well, but you will occasionally have the same problem with the rod shapes. I just keep a piece of coat hanger in my pocket and stick it down the nozzle whenever it plugs.
Mark D.
/ Sand Blaster clogging - need help #18
Heres an idea for everyone.
When my dad does his sandblasting he just goes to the local sand/gravel pit and gets a ton of extra fine sand (just regular old sand)only costs a few dollars. All you have do then is spred it out to dry on something where you can scoop it back up (like a concrete pad , sheet of plywood, or poly tarp).Scoop the sand back up when dry ,place in a dry container of your choice and store until needed.
You can even reuse it a couple of times (really s..t..r..e..t..c..h your dollar).
As far as the "black blast" make sure its dry and/or try mixing it with a finer grit sand.
Just a thought.
/ Sand Blaster clogging - need help #19
Just a thought.
Look up "silicosis". When you breath fine sand dust into your lungs --- it does NOT come out. Ever.
Fine sand works great, but you need to dry it, screen it and take precautions to not breath the dust.
/ Sand Blaster clogging - need help #20
Yes. My dad does wear a resperator. But then you should always wear one no matter what media your using.
2008 CHEVROLET EXPRESS VAN (A60736)
2008 CHEVROLET...
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
4004SFL (A59228)
4004SFL (A59228)
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
