Heating Oil Same as Diesel.. NOT
/ Heating Oil Same as Diesel.. NOT #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Contrary to lot's of opinions here.
I put some in my truck yesterday, GMC DuraMax, made it about a mile.
/ Heating Oil Same as Diesel.. NOT #2
sure it wasn't contaminated, was it kero or fuel oil?
/ Heating Oil Same as Diesel.. NOT #3
Can only state what I do know ......... and that is a local fella that sells fuel oil says it is the same but with dye ........... and that a local contractor uses it exclusively to fuel his fleet of dozers, backhoes, excavators and everything else that runs on diesel.
And I'm sure they're aware of the contrary regulations.
/ Heating Oil Same as Diesel.. NOT #5
local guys here fuel their tractors strait out of the FO tanks all year long. Maybe you just got some really bad timing and a clogged fuel filter or something.
/ Heating Oil Same as Diesel.. NOT #6
My neighbor called the local fuel company that sells diesel and home heating oil. He wanted diesel for his tractors and HHO for his house. Truck pulled in and filled up the house with HHO.. then backed up and filled up his diesel tank with the same stuff. Only difference.. he was charged a 5 cent/gal fuel tax for the fuel that went in the tractor tank!! :confused:
/ Heating Oil Same as Diesel.. NOT #7
In my part of the country it is. We only have 2 suppliers and they do not sell enough HHO so they simply use Off Road Diesel. Both are dyed red around here.
Chris
/ Heating Oil Same as Diesel.. NOT #8
That doesn't add up. There's at least 1/2 gallon of fuel in the pump, filter and lines. For the new fuel to have affected the motor, you'd be getting very poor mileage. (Unless there is a sensor in the fuel pump !!! ???).
/ Heating Oil Same as Diesel.. NOT #9
Jake, you have to be more specific, what did you do to get the truck running again and what did you find in the fuel filters?
/ Heating Oil Same as Diesel.. NOT #10
I had a 93 -250 with a 7.3 liter Diesel, Never ran HHO in it but was told by everybody that it would be fine, knew several excavators that did.Was told a few years ago, when looking at a 2006 GMC w/ Duramax, that the engine had some kind of electronic "eye" that would keep it from running correctly on heating oil because of the dye....Supposedly the diesel was clear enough to read "thru", the HHO wasn't. Don't have any further info since then tho. Good luck.
Mike
/ Heating Oil Same as Diesel.. NOT #11
Around here we have #1 and #2 diesel. Home heating oil is a blend with more #1 in the winter the same as the gas stations do in this state with diesel fuel in winter. I have run both types in my 05 duramax just fine although one of the guys at the fuel dock told me that some of the newer trucks were having trouble running on straight number 2.
/ Heating Oil Same as Diesel.. NOT #12
Mike
Not true. I have ran well over 300 gallons of dyed fuel though a 07 Dmax. and well over 2,000 gallons in a 04 and 06 Powerstroke.
Chris
/ Heating Oil Same as Diesel.. NOT #13
Like the others, I'd love to hear the specifics. You say you put "some" in the tank. Unless the tank was bone dry it mixed with what you had. How much DID you put in and how much road diesel was in there already?
It is possible for the fuel you burned at the end of that mile to have come from the tank (depending on mileage, filter size, line length, line ID) but I doubt it would stop the engine cold unless there was a some kind of sensor that shut off the fuel. But it would have to be one heck of a sensor to figure out what kind of diesel you're burning, IMO. Maybe it was a pump failure. Again, post more specifics before making a grand statement like that.
BTW, I used to burn HHO in my earlier diesels for years. No problem, as the others said, it's the same as # 1. But, then again, there was a lot less computer gadgetry and sensors on those vehicles.
It felt sluggish at about 1 mile, engine light came on and it wouldnt do over 2000 rpm without 'ocillating' rpms. Drained it out, filled it with diesel, ran it today and the light went back out. I put about 15 gallons HHO in while it had about 5 diesel left in there. It runs perfect again after I drained and refilled it. It's an 04.
To be accurate, I don't know what kind of HHO it was, we tested for water before we pumped it out of the in-ground tank, and there was none.
/ Heating Oil Same as Diesel.. NOT #15
Why are you running it in a truck anyway?
/ Heating Oil Same as Diesel.. NOT #17
Chris
Good to know. One of those things you hear, but unless you know someone with personal experience, you never know.
Mike
/ Heating Oil Same as Diesel.. NOT #18
Jake, I put a banks econotuner on my 05 duramax along with a different exahust, it worked great for a month then coasting down a long long hill coming down the alcan all of a sudden my engine light did that and truck wouldn't rev up just limped down the road til I could pull off. Was in the middle of nowhere so shut it down check elec connections, fuel etc couldn't find anything. Started it back up and all was fine and never did it again, check eng lite went off and everything. So by the time I got to Or. bought a tractor built a flatbed out of a boat trailer did the holidays I plumb forgot about it. Til...Had the trailer loaded for home @10 ton, was pulling out the driveway and the same thing happened. Backed back in checked everything, turned it off and restarted and same thing as soon as I pulled out. Backed in, called Banks they said that the extra power from the system plus the new heavy load I was pulling was making the slip sensor on the transmission set off the "limp home mode". They said to just go a couple of miles down the road limping, turn it off, then start it again and it would reset to the new parameters. I did, it did, and made it up the Alcan with the load just fine after that. Haven't had a problem since and when I talked later to a gm mechanic, he said that it happens sometimes even without the extra power of the banks. Sorry for being so long winded, but yours sounds like what was going on with mine. Good Luck
Rick
/ Heating Oil Same as Diesel.. NOT #19
I haven't heard of anyone having problems running any of the off-road fuels here ... but ... I have heard of them getting fined by FDOT. They are not only checking semi's, they are checking others, too.
They (the state of Florida) need the money, too.
/ Heating Oil Same as Diesel.. NOT #20
In January 2007 I converted to natural gas heating. Emptied the heating oil tank and dumped into an empty 250 gal tank beside my shed. That fuel probably pumped into the original tank Nov or Dec 2006 is still running my little Honda 6522 diesel, with no apparent ill effects.
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
24in excavator tooth bucket (A61307)
24in excavator...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
PRIME 8312 BOX (A63291)
PRIME 8312 BOX...
