learnin' to use the backhoe
/ learnin' to use the backhoe #1
V1Rotate
New Holland TC 29D
I recently picked up a TC-29 with a Woods backhoe, this is my first CUT so I needed to learn how to use it. I've watched many exprienced operators use backhoes and boy do they make it look easy. After a few hours now I think I'm getting the hang of it, but it takes a lot of eye-hand coordination which takes some practice, (at least for me). My goal is to be able operate the backhoe as efficiently and as smoothly as possible without putting any excess stress on it or the tractor. I was wondering if anyone else went through this with their backhoe and had any advice.
/ learnin' to use the backhoe #3
Best advice is "Keep diggin"............... You'll get it.
I found that when I dug the trench for the first 150' of french drain ....... the number two stones I used were my best friends.
They made the roller coaster bottom of the trench look nice and smooth ...... like the operator actually knew what he was doing.:)
/ learnin' to use the backhoe #4
Practice, practice.
Yep, and don't be any hurry initially. Speed will come, but you can learn bad habits by rushing it.
/ learnin' to use the backhoe #5
I learned by digging out rocks and stumps. Go slow and easy ,and just play with it. Try picking up rocks ,the more you try the better you'll get. Before long you'll be able to curl your bucket around a rock right in the hole, pick it up and shake out the dirt in the hole. Like they all said practice, practice, practice. Don't forget to ask Q's to anyone you know that runs them ,they'll give you some good tips on how they do things.
/ learnin' to use the backhoe #6
With enough hours of backhoe operation under you belt the need for hand eye coordination seems to go away. Eventually the boom, dipper, and bucket are just like an extension of your arms. They basically do what your mind tells them to without you even having to think about which way to move the sticks.
Whats real fun is going back and forth between a 2-stick machine and a 4-stick machine. Even though I have many hours on both it always takes me a second to adjust to the different controls.
/ learnin' to use the backhoe #7
As others have said, practice, take you time, and practice. Don't rush things, do it right and it will become natural for you. Took me a few hours and now feel very comfortable using the backhoe. :)
/ learnin' to use the backhoe #8
If you are going to be moving lots of rocks and trees, check out Bro-Tek: Tractor Add Ons, they make a "thumb" for on your hoe, it works just like your thumb for picking up items. I just installed one on a L 2500 Kubota and it's incredible how much time you save trying to pick items up. I pick up a 30 foot log to waist height then hit it with the chain saw, presto, no more bending over with the saw. Check out the video of people using the thumb. Your skill will come gradually, don't try and hurry, it's hard on your machine. Good luck.
/ learnin' to use the backhoe #9
That's a fact Verticaltrx. I remember back in the 60s when we had a local guy put in a bunch of waterline for us...his rates were by the foot while a lot of others were by the hour at that time. This really pleased all the old tightwad farmers around since they all had gotten quotes from the hourly guys and "knew" the guy was working cheap. The thing was, he could dig more feet/hour than any of them could so his "hourly rate" was actually higher than them! He was one smooooth operator though! Watching his boom motions was quite literally like you were watching someone move their arm in the same motion. No wasted motion, and no wasted time. He might have been a natural at it, but no doubt he had lots of experience too.
/ learnin' to use the backhoe #10
Yes, it does take some practice using backhoe (or BH) before you get the hang of it...:thumbsup:
/ learnin' to use the backhoe #11
Concentration always, practice makes it easier, techniques increase efficiency.
One thing though is your hoe will never be long enough!
/ learnin' to use the backhoe #12
"They" say one of the best ways to learn how to operate a BH is to watch an experienced operator. I agree. If you don't have an 'experienced operator' arond to watch :D then you might want to check out some youtube videos showing some very experienced operators doing some very interesting things with BH's. It won't replace your own experience and practice but I think it can help.
/ learnin' to use the backhoe #13
One thing that reduces the strain on your hoe is to concentrate on making the bucket slice through the ground i.e. pay attention to the angle of attack of the bucket and teeth. Lots of new operators try to dig with the bucket improperly angled are forcing the bottom against the trench as the dipper swings inward. Learn to counteract for the dippers arc by adjusting the bucket to maintain a flat bottom trench with the least strain on the tractor.
Nothing like seat time to improve your skills.:)
/ learnin' to use the backhoe #14
Nothing new to add - will echo patience and practice...
IMHO, the BH is my favorite implement - the most fun to use. Unfortunately, it is the one for which I have the least requirements. I am always looking for an opportunity to put it to use - volunteer it all the time just to get the practice. Also have added new projects to my list that I would not have otherwise - so watch out for that! :D
Take your time and enjoy!
/ learnin' to use the backhoe #15
Verticaltrx nailed it. After a while you will stop thinking about the controls as a separate function. You will get into a Zen-like state where the controls are one with you.
It is like typing (obviously something you can do). We don't think about every letter typed. The word comes and the fingers respond without conscious thought.
But it takes time and experience to get to that point. Just relax and let it happen. It will come.
/ learnin' to use the backhoe #16
Think left lever equals upper body, and upper arm, and the right lever equals forearm, and wrist. Bringing the two together just takes practice.
/ learnin' to use the backhoe #17
The teeth do alot of the work, you have to keep them parallel to the intended bottom of the trench. I used to watch my dad and the way he moved the levers back N forth was an art form. When you move another lever toward you w/ one already back both functions stop that seemed to be as important as picking which lever he wanted to use. By pulling the next motion b/4 releasing the one he was using he could make the bucket, boom & dipper dance to his will...took years to gather those skills.
You won't learn it overnight. Get started!
I remember watching a Union operator. The boss & engineer told him where the sewer & water mains were and how deep each were located. He located each pipe by feel knowing just when to stop and have a laborer uncover them w/ a shovel...That was a 225 CAT excavator w/ teeth as wide as your hand and a bucket 22" wide...the guy was amazing...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
Informational Lot - Financing (A63689)
Informational Lot...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
