CAB Top Repair Suggestions?
/ CAB Top Repair Suggestions? #1
Nuru
Elite Member
Anyone have any recommendations for repairing the gouges my CAB's top? I foolishly let my garage door rub the top for a while and now that I have fixed the issue, I wanna repair the gouges and scratches in the top.
a new one is ~$500 bucks, so before I go that route, I wanna explore fixing it.
/ CAB Top Repair Suggestions? #2
Depending on how deep the gouges are, you should be able to fill them in with body putty or spot filler. Then sand it smooth and repaint it.
/ CAB Top Repair Suggestions? #3
^^^x2 on that. If you can't do it see what your local autobody repair shop would charge for it.
/ CAB Top Repair Suggestions? #4
My mother when driving has scuffed up and bruised her front bumper a few times.:laughing: I found the bumper repair stuff to work well bonding to these plastic(?) materials. A little different formulation than the spot repair stuff but works about the same. That is what I would use on your top if it is plastic.
/ CAB Top Repair Suggestions? #5
What is the top actually made from?
/ CAB Top Repair Suggestions? #6
If the top is fibre glass, go to a marine store and get their repair material. Made especially for glass repair.
/ CAB Top Repair Suggestions? #7
I have used the fiberglass sheets to repair a broke top, but for gouges maybe all you'd need is the glue without the sheet? How deep are the gouges, are there cracks? the fiberglass repair kits are fairly simple to use and are very strong.
/ CAB Top Repair Suggestions? #8
It is a plastic compound not fiberglass, same as the fenders.
/ CAB Top Repair Suggestions? #9
You can just weld the plastic with a soldering iron. Just grab some scrap of the same stuff from someplace inconspicious and weld away.
Rick
/ CAB Top Repair Suggestions? #10
If it is a few small places, I'd suggest Brownell's Acraglas. You may can mix a little green paint with it or do the mixing on a John Deere catalog as it will take on some of the color of whatever it is mixed on. It is super tough stuff.
Not too deep but there are a number of them. The deepest may 1/4" at the most
I will post some pics soon, and let everyone have a gander at my challenge.
Thanks for all the responses! I will post some pics soon, and then everyone can see what I am gonna tackle
did you say it was fiberglass or plastic?
I believe it is the same plastic as the fender, just a lot denser
here are some pics
I guess the scratches are not that deep. They look like I could sand them down with 80 - 100 grit sandpaper, blow away all the debris and spray paint.
/ CAB Top Repair Suggestions? #16
Ouch.... :eek: Nuru, have you asked your dealer how they deal with damage to plastic components? I'd guess that they have to repair shipping and handling problems on new equipment - on occasion. They might even have some type of special "plastic paint" that incorporates (bonds) into the plastic rather that just laying on the surface.
Interesting thread - very curious to see a good solution.
AKfish
/ CAB Top Repair Suggestions? #17
Nuru,
That is definately in the realm of the bumper repair materials, you can mix it up similar to bondo and spread it over the gouges similar to spot putty. Sets up quickly and sand smooth.
AKfish
AKfish, no I have not, but I will probably do that this week. It would be great if they had something.
Nuru,
having looked at it today, I probably can just sand it down a bit and spray it, with JD Green and some clear.
/ CAB Top Repair Suggestions? #20
Ouch is right, you did this deliberately ?
You need your cab privileges taken away for a while. :laughing:
