CAB Top Repair Suggestions?
   / CAB Top Repair Suggestions? #1
Nuru
Elite Member
Anyone have any recommendations for repairing the gouges my CAB's top? I foolishly let my garage door rub the top for a while and now that I have fixed the issue, I wanna repair the gouges and scratches in the top.
a new one is ~$500 bucks, so before I go that route, I wanna explore fixing it.
   / CAB Top Repair Suggestions? #2
Depending on how deep the gouges are, you should be able to fill them in with body putty or spot filler. Then sand it smooth and repaint it.
   / CAB Top Repair Suggestions? #3
^^^x2 on that. If you can't do it see what your local autobody repair shop would charge for it.
   / CAB Top Repair Suggestions? #4
My mother when driving has scuffed up and bruised her front bumper a few times.:laughing: I found the bumper repair stuff to work well bonding to these plastic(?) materials. A little different formulation than the spot repair stuff but works about the same. That is what I would use on your top if it is plastic.
   / CAB Top Repair Suggestions? #5
What is the top actually made from?
   / CAB Top Repair Suggestions? #6
If the top is fibre glass, go to a marine store and get their repair material. Made especially for glass repair.
   / CAB Top Repair Suggestions? #7
I have used the fiberglass sheets to repair a broke top, but for gouges maybe all you'd need is the glue without the sheet? How deep are the gouges, are there cracks? the fiberglass repair kits are fairly simple to use and are very strong.
   / CAB Top Repair Suggestions? #8
It is a plastic compound not fiberglass, same as the fenders.
   / CAB Top Repair Suggestions? #9
You can just weld the plastic with a soldering iron. Just grab some scrap of the same stuff from someplace inconspicious and weld away.
Rick
   / CAB Top Repair Suggestions? #10
If it is a few small places, I'd suggest Brownell's Acraglas. You may can mix a little green paint with it or do the mixing on a John Deere catalog as it will take on some of the color of whatever it is mixed on. It is super tough stuff.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2835 (A54757)
2835 (A54757)
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
