Quick Hitches Newbie 3pt question
/ Newbie 3pt question #1
svdsinner
JD4020 w/46A Loader
My old tractor (JD4020) got totaled by a drunk driver and I'm combing the used market for a replacement tractor/loader with 80hp minimum
Some of the local tractors I've seen have CAT3 hitched on back.
Are there ways to attach CAT0 or CAT1 attachments to a CAT3 hitch?
Example would be to use a broadcast spreader or similar homeowner items behind a big old tractor that has a 540 PTO?
/ Newbie 3pt question #2
Anything can be done with fabrication, but I would try to stick with cat II.
Why? I'm not trying to make small implements do more. I just want a single tractor to handle both big and small chores. (serious question)
/ Newbie 3pt question #4
Double/triple bushings I guess, but that's kinda awkward. Plus, I'm not sure you can even close Cat 3 lower arms enough to attach a Cat 0 implement. That's ATV and garden tractor stuff. Even if one actually attaches, you'll still need a pretty good supply of shear bolts/lift pins/toplinks for those Cat 0/1 implements. My 45hp has a Cat 2 hitch, and I've bent up plenty of toplinks and lift pins on many Cat 1 implements that couldn't handle the extra power. Personally, I'd recommend folks shopping in the 40-100hp range limit their tractor selection to those with Cat 2 hitches.
//greg//
/ Newbie 3pt question #5
You could go to a machine shop and have some bushings made for cat3- cat1 and another set for cat3-cat2. But if you're using cat1 equipment with a 80 or 90 hp tractor, I'm guessing if you're not careful you'll only need the bushings for a short while cause you'll tear up the equipment.
Wedge
2015 Kia Optima (A66738)
2015 Kia Optima...
1457 (A65054)
1457 (A65054)
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
