suggestions/recommendations for new trailer
/ suggestions/recommendations for new trailer #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I am close to making an agreement with a trailer builder beside the wiring issues that have been posted are there any other ? or requests that I should discuss with the builder? 16' utility 2 tandem 5200 lbs retractable jack stem, room for tongue tool box, flat back no turn down, slide in ramps metal squares for railing 15" tires. anything else I should consider. Thanks for any and all replies.
/ suggestions/recommendations for new trailer #2
What are you looking to haul again?
/ suggestions/recommendations for new trailer #3
Rear jacks or legs to keep it from tipping and going for an unexpected ride when loading not hooked to vehicle.
What happens you drive on ramps back of trailer go's down front go's up lifts of front jack and trailer scoots away with you half on and off.
tom
/ suggestions/recommendations for new trailer #4
tom
Awesome. Zactly what I was gonna say. They also help when loading and unloading even when hooked.
I will add good rubber. No cheap Chinese trailer tires and trailer brakes if it's used on the road.
Plenty of tie down mounts.
crusher-run,57,357,LG rocks from the quarry, 3 to 4.5 ton at a pop cannot always get it right , saw dust, manure,compost,hay, building material, RC lumber, logs, fire wood. B7800 or L 3700 with FEL.
Excellent !
/ suggestions/recommendations for new trailer #7
I would consider using the same size rim/tire as your tow vehicle if at all possible. Of course, this is often impractical. Can never have too many spares since it is not uncommon to have two flats on the same side when it all goes wrong.
/ suggestions/recommendations for new trailer #8
You did good going with 5200lb axles, seen alot of bent 3500lb axles on 16' trailers, especialy when turning with a load, they is alot of axle twisting torque and I myself have rolled a few tires off the rim, always check tire pressure before hauling heavy loads.
/ suggestions/recommendations for new trailer #9
I would second the motion on some type of jacks or supports in the back for loading my tractor. Pick the back tires of your truck up and you have no brakes to hold it. Have seen trucks end up in a pond and in the back of another truck because of this. Definitely new tires, good wire connections under the trailer. Sounds like you are on the right track.
/ suggestions/recommendations for new trailer #10
Hey doall, a trek 5900, is that a mountain bike, I think they made of carbon fiber, they are very light.
/ suggestions/recommendations for new trailer #11
This has not been possible since the 1980's. Nothing but compact cars use 15" wheels anymore and even if you have a heavy trailer like my uncle with 7K axles and 8 lug wheels that are 16" the wheels from a 3/4 or 1 ton pickup will not fit due to the hub on the trailer being too large to fit though the hole on the wheel.
If you need more than 1 spare, and many times I carry two extra spares in the bed of my truck along with the one mounted on the trailer. The are relatively cheap at about $200 each for new ones or you can get a wheel and a junk yard tire for about $70 in my area.
Chris
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
2025 44in Hydraulic Grapple Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
Caterpillar 615C Scraper Service and Parts Manuals (A63117)
Caterpillar 615C...
