Flat tire repair
/ Flat tire repair #1
nickel plate
CA
2002 New Holland TC40S
I have a UTV with low mileage all terrain tires (non Slimed) and have discovered a flat caused by a 4-5 penny nail which penetrated through one of the center 3/8" +- raised treads. Should I repair it with the glue and synthetic twine-like product, a rubber plug or? Not sure how thick the balance of the tire casing is and I don't know if the plugs are available long enough. Please if you can, include your recommended product's brand name. I have an air compressor so I don't necessarily think that I need the hand pump type kit but maybe I do. Your thoughts please.
/ Flat tire repair #2
I have used Slime tire plug kits on all kinds of off road tires with 100% success.
Tractors, ATV's UTV's etc.
/ Flat tire repair
Thanks timswi, do I need to get a certain length of plug? Same size as the penetration or longer? A mixed package?
/ Flat tire repair #4
The ones I've bought are all the same size. They are plenty long enough for ATV and small tractor tires. AutoZone/pep boyes etc all have them. Brand doesn't really matter.
They come in a kut with the roughing tool, intallation tool, inserts and glue.
I always have a set or two laying around. They're cheap.
Some people like to put slime in the tires. That is a great solution except some tire shops surcharge you if that stuff comes splashing out. It's can make quite a mess.
/ Flat tire repair #5
I recently used the slime kit on my ZTR exmark (13psi rear tires) and it worked well. In addition I slimed the two rear for future insurance. The plugs are an easy quick fix without taking the tire off the rim.
/ Flat tire repair #6
I, too, have used the plugs for many off-road tire punctures, also with 100% success. Mine just happen to be Slime brand but I don't think that matters a bit. As long as you find the tools, glue, and plugs at an auto parts store or WallyWorld you'll be good to go.
I've plugged car tires, too. That might be a no-no, but I've never had a failure with one of them, either. YMMV
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2017 Nissan Juke SUV (A61574)
2017 Nissan Juke...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2022 EZ-GO ELITE...
