Flat tire repair
/ Flat tire repair #1
nickel plate
CA
2002 New Holland TC40S
I have a UTV with low mileage all terrain tires (non Slimed) and have discovered a flat caused by a 4-5 penny nail which penetrated through one of the center 3/8" +- raised treads. Should I repair it with the glue and synthetic twine-like product, a rubber plug or? Not sure how thick the balance of the tire casing is and I don't know if the plugs are available long enough. Please if you can, include your recommended product's brand name. I have an air compressor so I don't necessarily think that I need the hand pump type kit but maybe I do. Your thoughts please.
/ Flat tire repair #2
I have used Slime tire plug kits on all kinds of off road tires with 100% success.
Tractors, ATV's UTV's etc.
/ Flat tire repair
Thanks timswi, do I need to get a certain length of plug? Same size as the penetration or longer? A mixed package?
/ Flat tire repair #4
The ones I've bought are all the same size. They are plenty long enough for ATV and small tractor tires. AutoZone/pep boyes etc all have them. Brand doesn't really matter.
They come in a kut with the roughing tool, intallation tool, inserts and glue.
I always have a set or two laying around. They're cheap.
Some people like to put slime in the tires. That is a great solution except some tire shops surcharge you if that stuff comes splashing out. It's can make quite a mess.
/ Flat tire repair #5
I recently used the slime kit on my ZTR exmark (13psi rear tires) and it worked well. In addition I slimed the two rear for future insurance. The plugs are an easy quick fix without taking the tire off the rim.
/ Flat tire repair #6
I, too, have used the plugs for many off-road tire punctures, also with 100% success. Mine just happen to be Slime brand but I don't think that matters a bit. As long as you find the tools, glue, and plugs at an auto parts store or WallyWorld you'll be good to go.
I've plugged car tires, too. That might be a no-no, but I've never had a failure with one of them, either. YMMV
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
Pallet of Club Car Golf Cart Seats (A64912)
Pallet of Club Car...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A66734)
2025 Wolverine...
AGT LRT23 (A64912)
AGT LRT23 (A64912)
Club Car Emergency Cart (A64557)
Club Car Emergency...
2021 Deere 331G (A64911)
2021 Deere 331G...
