Hyd Cyl for front hitch angle kit??
   / Hyd Cyl for front hitch angle kit??
Scout, Thanks for the further information. I have been looking at a 1 1/2 x 6" stroke from Surplus Center and the dimension are about 1" shorter. But nothing else is even close. Guess I'll keep looking. I would hate to have a custom one (2) made up. --- Tom
   / Hyd Cyl for front hitch angle kit?? #12
Sorry for the delayed response gents, been up to my ___ in projects.
Yes, the bore is 3/4".
The extended length is ~ 21", and the fully closed length is ~ 14".
Hope this helps!
Thanks for double checking. I'm ordering the cylinders tomorrow.
Cub --- Have you found a source for a matching cylinder?
Thanks ----- Tom
   / Hyd Cyl for front hitch angle kit?? #14
Hope this helps!
Those measurements were from center eyehole to center eyehole, not total length....hope I didn't confuse anyone.
   / Hyd Cyl for front hitch angle kit?? #15
Thanks ----- Tom
Yes, Here's what I ordered from surpluscenter.com
I measured the hole to hole length of my lift and its close to 18". These cylinders have a 14" closed length with a 8" rod length. That means that when the cylinder extended halfway it will be right at 18". The diameter of the rod isn't quite what he spec'd but I couldn't find anything closer with swivel ends. This is everything needed for an angle kit. Cost is less than just one hyd cylinder from Cub.
2 9-7257-8 1X8X0.625 DA HYD CYL SWIVEL EYES 191.90
1 9-6803-6-6-6 JIC 6M/JIC 6M/SAE 6M TEE 2.50
2 9-6802-6-6 JIC 6M TO SAE 6M 45 ELBOW 4.50
2 9-6801-6-6 JIC 6M x SAE 6M SWIVEL 90 ELBOW 5.78
2 920-2218 1/4" X 18" JIC 4F X JIC 4F 5000 PSI HYD H 14.98
2 921-2260 1/4" X 60" JIC 6F X JIC 6F 5000 PSI HYD H 27.98
1 9-304-C-6 JIC 6 CAP 0.45
1 9-6314 1/4" NPT QUICK COUPLER S40-2 14.95
2 9-2503-6-4 JIC 6M x 1/4 NPTM 45 ELBOW 3.50
PRODUCT 266.54
Cub,
Thanks for the great info. --- Tom
   / Hyd Cyl for front hitch angle kit?? #17
Cub,
Bear in mind that I haven't installed this yet so it's not a tested set up. The only thing I need is the bolts and spacers. I am not sure of the quick connect couplers. They look correct but I won't know until I get them. They were only $14 so its worth the chance.
   / Hyd Cyl for front hitch angle kit?? #18
Got my order today and noticed an error right off. This item:
"920-2218 1/4" X 18" JIC 4F X JIC 4F 5000 PSI HYD H 14.98"
should have been a JIC 6F X JIC 6F . When I reordered I also only ordered a 12" length which is plenty. Test fitting looks okay but I won't be able to assemble it until the weekend.
Cub, Keep that info coming!! I return home at end of next week and plan on measuring and ordering up the parts then. We've already had our first snow and I need to be ready. How did you address the 1/2" cylinder swivel holes and 5/8" pins on the mount? -- Tom
   / Hyd Cyl for front hitch angle kit?? #20
I haven't mounted it up to the lift yet so I'll have to see. If the hole is for a 5/8" pin I might have to sleeve a 1/2" pin or worst case would be to weld new plate and drill a new hole to fit 1/2". Either way its not a problem. Right now I'm elbow deep into a 5234 transmission rebuild.
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
