Hyd Cyl for front hitch angle kit??
   / Hyd Cyl for front hitch angle kit??
Scout, Thanks for the further information. I have been looking at a 1 1/2 x 6" stroke from Surplus Center and the dimension are about 1" shorter. But nothing else is even close. Guess I'll keep looking. I would hate to have a custom one (2) made up. --- Tom
   / Hyd Cyl for front hitch angle kit?? #12
Sorry for the delayed response gents, been up to my ___ in projects.
Yes, the bore is 3/4".
The extended length is ~ 21", and the fully closed length is ~ 14".
Hope this helps!
Thanks for double checking. I'm ordering the cylinders tomorrow.
Cub --- Have you found a source for a matching cylinder?
Thanks ----- Tom
   / Hyd Cyl for front hitch angle kit?? #14
Hope this helps!
Those measurements were from center eyehole to center eyehole, not total length....hope I didn't confuse anyone.
   / Hyd Cyl for front hitch angle kit?? #15
Thanks ----- Tom
Yes, Here's what I ordered from surpluscenter.com
I measured the hole to hole length of my lift and its close to 18". These cylinders have a 14" closed length with a 8" rod length. That means that when the cylinder extended halfway it will be right at 18". The diameter of the rod isn't quite what he spec'd but I couldn't find anything closer with swivel ends. This is everything needed for an angle kit. Cost is less than just one hyd cylinder from Cub.
2 9-7257-8 1X8X0.625 DA HYD CYL SWIVEL EYES 191.90
1 9-6803-6-6-6 JIC 6M/JIC 6M/SAE 6M TEE 2.50
2 9-6802-6-6 JIC 6M TO SAE 6M 45 ELBOW 4.50
2 9-6801-6-6 JIC 6M x SAE 6M SWIVEL 90 ELBOW 5.78
2 920-2218 1/4" X 18" JIC 4F X JIC 4F 5000 PSI HYD H 14.98
2 921-2260 1/4" X 60" JIC 6F X JIC 6F 5000 PSI HYD H 27.98
1 9-304-C-6 JIC 6 CAP 0.45
1 9-6314 1/4" NPT QUICK COUPLER S40-2 14.95
2 9-2503-6-4 JIC 6M x 1/4 NPTM 45 ELBOW 3.50
PRODUCT 266.54
Cub,
Thanks for the great info. --- Tom
   / Hyd Cyl for front hitch angle kit?? #17
Cub,
Bear in mind that I haven't installed this yet so it's not a tested set up. The only thing I need is the bolts and spacers. I am not sure of the quick connect couplers. They look correct but I won't know until I get them. They were only $14 so its worth the chance.
   / Hyd Cyl for front hitch angle kit?? #18
Got my order today and noticed an error right off. This item:
"920-2218 1/4" X 18" JIC 4F X JIC 4F 5000 PSI HYD H 14.98"
should have been a JIC 6F X JIC 6F . When I reordered I also only ordered a 12" length which is plenty. Test fitting looks okay but I won't be able to assemble it until the weekend.
Cub, Keep that info coming!! I return home at end of next week and plan on measuring and ordering up the parts then. We've already had our first snow and I need to be ready. How did you address the 1/2" cylinder swivel holes and 5/8" pins on the mount? -- Tom
   / Hyd Cyl for front hitch angle kit?? #20
I haven't mounted it up to the lift yet so I'll have to see. If the hole is for a 5/8" pin I might have to sleeve a 1/2" pin or worst case would be to weld new plate and drill a new hole to fit 1/2". Either way its not a problem. Right now I'm elbow deep into a 5234 transmission rebuild.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
Nissan Forklift (A55973)
Nissan Forklift...
