Hyd Cyl for front hitch angle kit??
   / Hyd Cyl for front hitch angle kit?? #1
tcfamy
Superior, WI
Cub Cadet 5234D
Greetings,
Does anyone have the specs on the hydraulic cylinders for the front mount angle kit (590-623-100) for the 5000 / 6000 / 7000 series Cub? Nothing is available thru the dealers and on the usual Ebay, Craigslist. I tried matching up the fixed link to available cylinders from several suppliers, but nothing is intuitively correct. So if you have diameter x stroke, and any other specs - greatly appreciated. I can work on the rest.
Tom
   / Hyd Cyl for front hitch angle kit?? #2
If no one else responds I can get you the measurements in 3 weeks, when I get back home. I've got an angling kit on my 5234. I would think there should be some aftermarket cylinders that would fit?
Thanks Scout. Not a big hurry, but who knows when the first snow will hit here! ---- Tom
   / Hyd Cyl for front hitch angle kit?? #4
Scout, I would appreciate those measurements also.
   / Hyd Cyl for front hitch angle kit?? #5
No problem....I get home on the 8th of October. I will get measurements and pics directly thereafter....
   / Hyd Cyl for front hitch angle kit?? #6
OK....looks like body length is 11".....the piston bore is 3/4".....I will get some more measurements tomorrow.
Thank you Scout!
   / Hyd Cyl for front hitch angle kit?? #8
Yes, thanks. That makes it much easier.
   / Hyd Cyl for front hitch angle kit?? #9
Just double checking, are you sure on the 3/4" bore? That seems kind of small compared to most cylinders I've seen for this use. Maybe because there's 2 of them instead of 1.
   / Hyd Cyl for front hitch angle kit?? #10
Sorry for the delayed response gents, been up to my ___ in projects.
Yes, the bore is 3/4".
The extended length is ~ 21", and the fully closed length is ~ 14".
Hope this helps!
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
1629 (A57192)
1629 (A57192)
Black Steel Diamond Plate (A55758)
Black Steel...
2012 International Derrick Digger (A55973)
2012 International...
