Snow New Snowblower
/ New Snowblower #1
blackd
So MD
Yanmar FX24D replaced with Massey GC2400
Picked up my MF 2360 snowblower today. It was, of course, near 90 degrees. Haven't done anything with it but to take the plastic cover off the main crate. Nice bright MF red.
I have done my best to save the midatlantic from snow this winter.
/ New Snowblower #2
Well it worked for me last year. Bought a new tractor with a new blower and used it twice on only a few inches of snow, we should have had feet of snow. So this year you will be safe and it will be our turn to get hit.
/ New Snowblower #3
It sees to work that when you're prepared you don't get any snow. When you do get the snow you'll love the 2360. It devours the snow and makes it go far, far away. The dealer assembled mine 2yrs ago. My friend assembled his a couple of weeks ago with electric chute and deflector controls. It took him about 10hrs by himself but he said he could do it again in 5hrs. He commented the instructions/pictures weren't that clear.
2007 GC2310TLB, 2360 Snowthrower W/electric controls, Box blade
/ New Snowblower #4
Yes, the snowblower sits there real nice in a glory of red. If we have a normal winter around here, I'll be using mine for the first time around Thanksgiving. Until then, the front loader will continue to rule the day, and there is still lots for it to do . . .
/ New Snowblower #5
Wouldn't mind seeing some pics of it when you get it set up. Anyone using the electric chute controls with their GC? How and where do they put the switches? Or does every dealer do it different?
/ New Snowblower #6
They stuck mine on either side of the dash -- of course, the 2310's dash is kinda old-fashioned compared to the new ones. Looking closely at the dash picture, the switches are just visible on the extreme upper left & right: rubber-coated momentary toggles.
The one thing I did do to the set-up was to add a flat-4 disconnect --with a rubber cover-- under the hood; that way removing the blower (and disconnecting the electric) is much easier.
Ditto what AMCS said- it really throws the snow!
  • dash 5:08.JPG
    dash 5:08.JPG
/ New Snowblower #7
Thanks irvingj, I did remember you showed me setup a long time ago. I was just wondering if they pretty much do the same on the 24/2600's. I was wondering if every dealer does it different or if it is pretty standardized.
/ New Snowblower #8
Both my switches are on the right side of my dash seperated by a couple inches. My ideal setup would be to have both switches built into the FEL knob so you wouldn't have to move your hand back and forth.
/ New Snowblower #9
Where'd you find such reasonably priced tools?
/ New Snowblower #10
I'm looking at getting a GC2600 with the 2360 front mount snow blower thinking it may be much easier on my back not having to turn around all the time to look at a a 3-point mounted snow blower. I was wondering how easy it is to attach/remove the 2360? Are there any sub-assemblies that you leave on the tractor when the snow blower is removed.
/ New Snowblower #11
dodes, There is a subframe and quick hitch assembly that connect the blower to the tractor. Most people choose to leave the subframe and quick hitch connected to the blower, and take the whole thing off the tractor when you want to disconnect. That gives you normal ground clearance at your front end for doing other things and using your front loader, etc. If you can keep your snowblower inside on a hard floor, see the recent posts about using a dolly to make it real easy to maneuver for connecting to the tractor. I am a new owner too and I did my first connect to the blower outside on semi-rough ground. You have to position the tractor pretty exactly but it wasn't an ordeal or anything. It will get easier with time, and I anticipate doing the connection only once per year. Still, the dolly thing seems pretty nice, and I do have a garage stall available if I kick a car outside and keep the tractor warmer inside . . .
/ New Snowblower #12
ScottW, thanks for the information. It sounds pretty straight forward. Now I'll just have to see if I can swing the extra cost.
/ New Snowblower #13
During the winter I always left the quick hitch on the tractor unless I needed the extra ground clearance but that was never an issue.
DEWFPO
/ New Snowblower #14
I take the thrower off the quick hitch when I remove it. I keep the thrower in the back of one of my garage bays on moving dollies from HF. I keep the quick hitch on a seperate dolly as its kind of heavy and I'm not as young as I used to be (hernia surgery both sides last June). By sticking the nose of the tractor into the garage it's so easy to roll everything up to the tractor and connect. The only lifting involved is the quick hitch to the frame.
/ New Snowblower #15
Ditto AMCS, ScottW and DEWFPO; I remove the blower, dropping it onto a dolly, but remove the quick-hitch assembly only if I need the clearance- it does not interfere with FEL operation.
I also put the quick-hitch on another dolly so it can be rolled out of the way when I do remove it.
Removing the blower but not the quick-hitch takes about 3 minutes; removing the quick-hitch (and the driveshaft) takes me about 7 minutes. Very easy, but the dollies help a lot, especially when re-attaching.
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
Landhonor Livestock Chute w/ Scale (A66408)
Landhonor...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
