Cleaning Greasy Zerks and Pivot Points
/ Cleaning Greasy Zerks and Pivot Points #1
Big Joe
Fayette County, TX
L4300DT
I mow in a pretty dusty environment and have a heavy accumulation of dirt and grease around the grease zerks and pivot points of the FEL on my Kubota. I clean the zerks with a rag the best I can before greasing, but some of them are pretty tough to get to. Should I use some sort of degreaser solution? What do you recommend?
/ Cleaning Greasy Zerks and Pivot Points #2
I wipe the tip with a finger and grease it.
/ Cleaning Greasy Zerks and Pivot Points #3
I just wipe the tip with a rag than pump grease in till I see a bit of clean grease squeeze through, usually 2-3 pumps.
/ Cleaning Greasy Zerks and Pivot Points #4
I usually just use a paper towel or rag to wipe off the excess or sometimes compressed air. You really have to watch some quick drying solvents for paint damage, but some will work well if it is important to you.
/ Cleaning Greasy Zerks and Pivot Points #5
I seen equipment w/plastic grease caps but after while the fall off etc.,or just leave very little grease at fitting end to collect dust/grit than wipe before pumping.
It looks as if I just need to apply some "elbow grease" to clean it up.:D
/ Cleaning Greasy Zerks and Pivot Points #7
I use an old rag or paper towel to wipe around the zerks before greasing, Also give a quick wipe after greasing to get rid of any excess grease, that way there in less for dirt to stick to. :D
/ Cleaning Greasy Zerks and Pivot Points #8
Same here, you can also kinda "hear" the cracking sound of the grease coming around the joint if you listen carefully.
James K0UA
/ Cleaning Greasy Zerks and Pivot Points #9
I just clean the top of the zerk...
/ Cleaning Greasy Zerks and Pivot Points #10
I wipe the bulk of it off with a paper towel. The rest I take off with mineral spirits. I have used mineral spirits for many years and, in my case, it has never harmed the paint. Mineral spirits are a petroleum based solvent. I don't think mineral spirits are any more harmful to the paint than the grease it is removing.
I greased it again yesterday and cleaned it up pretty good with paper towels. I'll try the mineral spirits suggestion to try to get the other residue off so that it's more orange than black.:)
Thanks for all your input. That's why I like TBN so much...a great bunch of people who don't mind helping.
/ Cleaning Greasy Zerks and Pivot Points #12
I have a brush and a can of solvent that I use once in a while to clean the area around the fitting and joint, then give the whole rig a bath with soap and water.
/ Cleaning Greasy Zerks and Pivot Points #13
My father in law swore by WD40 for cleaning. I am probably in the minority, but what a good shower won't wash off stays there.
/ Cleaning Greasy Zerks and Pivot Points #14
WD40 is pretty good stuff in this sense, its better than evaorative solves or soap and water, as WD40 is hydrophobic and leaves a nice coating of naphtha. To prevent rust.
/ Cleaning Greasy Zerks and Pivot Points #15
WD40 is pretty good stuff in this sense, its better than evaorative solves or soap and water, as WD40 is hydrophobic and leaves a nice coating of naptha. To prevent rust.
I love WD40! :thumbsup: (I even bought a gallon jug once) ;)
/ Cleaning Greasy Zerks and Pivot Points #16
My father in law bought it in the big non aerosol containers. We always have some on hand, but we don't use nearly as much as he did.
/ Cleaning Greasy Zerks and Pivot Points #18
Simple Green. Biodegradeable, rinses off with water, and is a pretty darn good degreaser.
I use to use that on my motorcycles and it worked pretty well, but offers no rust protection.
/ Cleaning Greasy Zerks and Pivot Points #19
I've always been a fan of WD40 until recently when I discovered that it absorbs and retains water over time - know how it turns white and kinda gloppy over time? It actually promotes rust in some environments.
As far as zerks - some of my backhoe and bucket pin-end zerks get packed tight with dirt. I have an old fine-blade screwdriver that is perfect for scraping around the zerk to dig out the dirt. Then I pack it full. Exposed zerks get a quick wipe with paper towel, but usually only if I can't see them. I leave the grease that globs out from both the joint and the zerk stay where it is. I am an overgreaser - I believe that a goodly portion of outer spooge keeps the actual inner joint and zerk protected from moisture and dirt. If you even think about standing next to my tractor, you're going to get a grease spot on your clothes somewhere :).
JayC
/ Cleaning Greasy Zerks and Pivot Points #20
I usually just wipe the zerks off with a paper/shop towel and grease them. After that there is a slight dab of new grease left on the zerk and I leave that on there so it'll be easy to wipe the zerk off the next time. If you have zerks that are hard to get to try wiping them off with a Q-tip.
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
24in excavator tooth bucket (A61307)
24in excavator...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
iDrive TDS-2010H...
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
iDrive TDS-2010H...
