Buying Advice tractor advice/
/ tractor advice/ #11
KU Gator, Triple R, peterc38, jgrreed, PushingTIn, and jlsmith,
Thanks for all the replies! Guess I might really be showing my ignorance..I really thought a 30 hp tractor would be able to push over small saplings and even smaller trees with relative ease. To me 30hp seemed alot...apparently not compared to what I want to be able to do with it! Id say that the 4 plus acre clearage maintenance is first, lawn and driveway nice to haves given i have stuff that covers that fine today.
The Kubota I mentioned does have an FEL..but I definitely don't want to be one of those newbies who decides on the solution before figuring out the problem...only to find out I don't have even close to whats needed.
I do of course have a chainsaw for any larger trees that were in the way..my 'plan' was to use the FEL to kind of push the saplings and smaller brush down and then brushhog over the top...to make a usable work trail...actually several..and then work off of that clearing a bit at a time...if there is a better way(s) I am all ears!
The rocks I had mentioned are likely in the 100-200 pound range..I can roll them or use pry bar into a bucket..but getting too old (and sore!) to move them manually....
Thanks again..already have learned alot in one day! - Stephen
Guess I could try to take a couple of pictures
It all depends on your definition of "small". I have been pushing some over with my L5030 and "mulching" them or dragging them off. A lot will also depend on your soil type and moisture content as well as type of tree.
With a little bit of practice and maybe even a tooth bar, you can probablt get a lot of those rocks in your bucket without leaving the seat.
/ tractor advice/ #12
I guess a lot depends on the type of sapling too. I think we have a lot of sumac. If you push it, it just bends over. I can acutally cut it with the brush hog or using a brush blade on a heavy duty weed wacker. I also bought a brush grubber to grab onto the saplings and pull. It is actually a pretty good product and using two people, it works pretty well. With only one person, there is a lot of getting on and off the tractor.
BAC Industries Brush Grubber, Model# BG-01 | Weed + Brush Removal | Northern Tool + Equipment
We also have some cedar which are pretty tough to pull out as well as black locust. The smaller Kubotas are pretty light, so they tend to run out of traction before they run out of power when trying to pull trees out of the ground. I don't have liquid in my tires, but usually keep my box blade on for extra traction, but still spin the wheels.
Rocks the size you are talking about are easy with the FEL. We have a lot of those which are no big deal. We also have some that are close to the size of a office desk that were stacked I guess when a water line was put in along the road right of way.
/ tractor advice/ #13
I do of course have a chainsaw for any larger trees that were in the way..my 'plan' was to use the FEL to kind of push the saplings and smaller brush down and then brushhog over the top...to make a useable work trail...actually several..and then work off of that clearing a bit at a time...if there is a better way(s) I am all ears!
Stephen, I think many people find removing trees by knocking them down with the tractor becomes an exercise in frustration. Horsepower is not the requirement; it's weight and traction that limit what a tractor can do. Tractors aren't bulldozers, and the physics of leverage just aren't in favor of a tractor pushing or pulling trees at or near ground level. As TripleR says, if the conditions are right, a good sized tractor can do it up to a certain size, but, inevitably, some trees require another tactic. So the idea you can blaze a semi-straight trail through the woods with a tractor often becomes the reality that some trees, maybe even most of them, need to be cut with a chainsaw and the stumps removed by other means or cut off flush to the ground and allowed to decay (for an atv trail, why not?). If your intended trails can meander some, you can often find a path that keeps the stump problem to a minimum, and a B sized Kubota might be perfect for snaking the downed trees out of the way. The other work... mowing, grading with a blade and the FEL, etc... you'll be amazed at what those little Kubota's can do. Of course, a bigger machine will work faster and do more if the budget allows for it.
All that said, if you don't have some experience doing this sort of thing, and you decide to go this route, please go easy and exercise the greatest of caution as you learn. Operating tractors - even one as small as the B Kubotas - can kill you if you're not careful. Downing trees - even small ones - can also kill you. Please learn what is and is not safe, so you can regale the folks here at TBN with your successes!
/ tractor advice/ #14
I couldn't agree more. I exercise the same degree of care and caution on my BX2660 as my L5030 or M8540. I have been driving tractors for over 50 years and am still learning. When I see what a pro can do with a tractor, it is kind of embarrassing.
I give the same advice on operating a tractor as riding an ATV, dirt bike RUV, etc and that is in a lot of situations, just get off the machine and walk the area to get a better idea of the terrain/conditions etc and think it over. If you have any doubts what so ever, don't do it until you can make any needed adjustments or get a little more practice/experience.
Some mishaps are just funny, see "Embarrassing Tractor Moments", it's on a thread somewhere here, but sometimes they can be deadly. We have lost two experienced operators in my area this year.
Not trying to scare anyone, just reinforcing some very good advice.
/ tractor advice/ #15
Just my two cents but I still think a B2910 is a good match for you. If you need to have someone come in with a dozer for a few hours and clear some of the larger areas.
What we are talking about is a B2910 which is an outstanding proven tractor w/ premium features in good shape (per your description) that has:
1.) only 150 hours
2.) FEL
3.) block heater
4.) scraper blade
5.) chipper
for 12K I'd buy it in a heartbeat. :thumbsup:
/ tractor advice/ #16
30 to 35 HP in a 3000 lb tractor would do a good job for you and not be to heavy for the lawn. A larger tractor would do the job faster, but after the clearing is done they would be larger than you need. Where are you located in NY?
/ tractor advice/ #17
Thanks very much for the quick response....so your saying you think a tractor along the lines of a 2910 (30 hp, my sole frame of reference for the moment) is too much after the initial work is done? I have run a tractor a few times at my in-laws place but would not consider myself more than just basically experienced.
You hit the nail right on the head as far as getting someone..its tedious work given its up in my back treeline...anyone you would trust to do it is far too pricey...and I definitely don't want it clear cut...I want to save many of the trees..put in atv trails, clear out the underbrush..grade a bit...the kind of work thats too time consuming that would cost too much to hire out. Seems my best bet to get it done right (vs. half *ssed) without costing me near the price of a tractor is to do it myself...
The above mentioned 2910 is a 4wd, low hours (150), nearby and seemingly good shape..has a large chipper, block heater, scraper blade, etc...seems a bit pricey (12K)... Definitely appreciate all the input! I don't want buyers regret at these prices 15 minutes (or hours!) later...
Don't know if these machines are in your area. I do not know what exactly they are called. They have a large rotating drum on the front of a big Bobcat style skid/track loader, they are one heck of a machine. We had HEAVY under brush on our property alot of laurels huge Rhododendron. I flagged all the trees we wanted to save and the fellas chipped everything else. The beauty of these machines is they do not disturb the soil just leave wood chips.We have had them out twice and they will be back again this winter. $100 per hour but it is worth every penny. The Forrest is thick on our property when they were done last winter the area they did was transformed to a park like quality. They also make great paths as the machines width with a little wiggle is approx. 8' If you need more specifics I can call them and ask. No piles, No windrows, No soil disturbance just chips.
/ tractor advice/ #18
You were right, the 30 horse is plenty of horses. The body size of the tractor is what someone was referring to as being to small for the tree clearing. An L series like the 30 horse one would do a lot more because of the extra weight. But I also agree that if you take your time the kubota you are looking at would be fine.
/ tractor advice/ #19
Greetings,
You should see about having someone
coming in and clearing the property with
tracked Fecon forest tractor with a brush
and tree chipping drum/land clearing head
or other brand to solve the issue for you,
and avoid issues like getting hurt from
making a mistake you cannot back away from.
leon
/ tractor advice/ #20
For the bush hogging and chipper, I'd be looking for 30+ HP, preferrably 35.
As for pushing over sapplings, it's all about tractor weight plus the strength of the loader. I have pushed over hundreds of 2 - 3" cherry, walnut, sassafras, maple, etc. with my 25 HP Kioti. Of course, it weighs about 5500 lbs with loader, backhoe, and filled tires. I've even pushed over 7" diameter spruces with little trouble. It's about weight. Then add a toothbar to help you.
The 2910 is a good buy if it has a loader.
For weight consider Kioti, Bobcat, Branson, Mahindra. If you can afford the MF1635, that's a real sweet tractor.
Don't buy too small and regret it later.
2010 Kubota M108S (A60462)
2010 Kubota M108S...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
2014 KENWORTH T370 QUINT/A  DUMP TRUCK (A59906)
2014 KENWORTH T370...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A60352)
2015 SkyJack SJ86T...
2014 FORD F-550 XL SUPER DUTY UTILITY/SERVICE TRK (A59823)
2014 FORD F-550 XL...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
