picker77
Gold Member
- Joined
 - Feb 4, 2006
- Messages
 - 386
- Location
 - Central Oklahoma
- Tractor
 - JD 3032E, dual remotes, TnT, tooth bar, grapple
Wow, rcbsaver, I really feel bad for you on this whole deal.
At the risk of being indelicate, and believe me I mean no offense at all here, maybe there should be another step:
3(a): Lay Chris' pre-assembled frame face up on a table and position both rails where they're supposed to go in accordance with the included pictorial assembly/welding diagrams that come with the frame from Chris. Then do a careful "sanity check" by spending a few minutes with a tape measure and a framing square to be absolutely dead certain everything will fit up exactly as it should compared to the dimensions and diagrams. Only THEN consider clamping and welding.
The framing square would have immediately highlighted the problem, namely the faces of the two rails would have been 1/2" different, and therefore the forks could not possibly fit properly.
It's a crying shame you had to go through this, but you've been patient and handled it well in spite of that, and it sounds like ATV is being decent about it. However, by doing 3(a) above, a phone call to ATV and another few days wait would have produced the right rail, end of problem. Maybe your ordeal will help somebody else avoid this nightmare.
Good luck and hang in there, friend! When this is over, at least you'll have the stoutest upper and lower fork rails on the planet!
