picker77
- Joined
- Feb 4, 2006
- Messages
- 386
- Location
- Central Oklahoma
- Tractor
- JD 3032E, dual remotes, TnT, tooth bar, grapple
We legions of happy Chris Perry fork owners should start a thread on ideas for alternate uses and attachments for the main frame. That neatly designed and lightweight basic frame (with forks removed) is just begging for clever applications of homebrewed steel. I have been ciphering on how to come up with a small brush grapple that could easily slide on the frame and be locked into the top notches similar to the setup on the forks.
After wasting a lot of pencil lead, brain cells, and graph paper, I came up with a couple of possibilities and began to research the cost of steel to build it. Unfortunately, this was followed by sticker shock on new steel prices akin to what I received when shopping for a new pickup truck several years back. After some honest cost vs benefit analysis, I trashed the whole idea and ordered a Greens Machine Shop's "The Thumb" in a 28" version (see The Thumb), along with an extra mounting base and flow restrictor. Total cost delivered was comparable to buying just the steel to build a typical 48" dedicated grapple, and I decided I'd rather spend the money on a bucket and fork thumb/grapple setup. The Green's Machine Shop thumb itself, which is stoutly built but has only two tines and is only 18" wide, may undergo a minor modification to make it a little wider (a pair of outboard tines to make it around 30" wide), and will be installed on my FEL bucket.
As for the extra mounting base, I want to see if I can modify it to lock onto my Chris Perry fork frame, yet still be easily removable, just like the individual forks. I'd rather not (and Chris would probably rather I not!) weld on the frame itself to get this all done. The idea is to be able to swap the thumb back and forth between the FEL bucket and the forks. In the meantime my current FEL bucket/tooth bar will be infinitely more useful with a removable thumb/mini-grapple attached.
BTW, David Green is a nice man to deal with, and he shipped my thumb the next day.
If all this pans out I'll post some photos. If it doesn't, I won't, LOL.
