Brake problems on 7k axle
/ Brake problems on 7k axle #1
Newblue
Gold Member
Central Indiana
New Holland TC45DA SS
I started hearing metal grinding sounds at low speeds while braking and noticed one of the drums was running hot to the touch. I had the wheels off to get the valve stems that were cracking replaced and decided to pull the hot drum. I found blue spots inside the drum and what looks like blue metal deposited on the front brake shoe. What would be causing this? I ran the brake shoes loose on this position Imediately after I heard the first grinding sound. I first heard the sound about 4 months after I got the trailer, then pulled all the drums and found the grease seals leaking and replaced them. The grinding sound still persists.
Thanks - Mike
/ Brake problems on 7k axle #2
One of three things it could be.
1st is a bad drum
2nd is a bad shoe
3rd is a piece of debris got into the brake and caused the issue.
Chris
1st is a bad drum
2nd is a bad shoe
Chris
Now that I think about it, when I first got the trailer, I pulled the drums to check the packing job and found an extra backing plate nut riding in the bottom of this drum . It rode in there for the first 1000 or so miles. I'll try taking a grinder and knocking off the metal in the shoe. Thanks Chris.
Mike
/ Brake problems on 7k axle #4
Mike
Mike, I would just get new shoes. They run about $25 per set at the trailer place or you can go to the auto parts store and match them up. All trailer stuff is old Ford. Like from the 60's and 70's when they had drum brakes on the rear. I have used Napa and Auto Zone shoes for years on 3.5K and 5.2K axles. Not sure of the part # for a 7K but a trip to a good parts guy will have you fixed up. Just take the old ones. Should save you a few bucks.
Chris
I will do that tonight. Thanks again.
Mike
/ Brake problems on 7k axle #6
i used a file to resurface "baked" brake pads of a sticky brake. Just skim the fine surface off so they are a little rough: brake twice and they'll be good to go again.
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 MACK CXU613...
PENDING SELLER CONFIRMATIONS (A59911)
PENDING SELLER...
2018 Ford F-150 4x4 Pickup Truck (A61573)
2018 Ford F-150...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
