Back seat truck boxes
/ Back seat truck boxes #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I recently bought a 2002 GMC 4x4 regular cab. I'd like some kind of box for behind the seats to store stuff in. It seems like years ago I remember when you could buy one that was sort of triangular shaped that would fit behind the seats. I'm looking for something to store a tow rope, tie downs, that sort of stuff in. I've searched on line, and it seems like everything is meant for crew cabs. Any ideas?
/ Back seat truck boxes #2
I think Northern Tool sells boxes to put under the seat.
/ Back seat truck boxes #3
Know nothing about the company, but here's a possibility:
Du Ha Truck Back Seat Storage Units
The price looks painfully expensive for a piece of plastic though.
Not long ago, you could buy these things at parts stores or Wal-Mart.
Given that regular cab trucks are getting to be an indangered species, this kind of stuff is getting a little harder to find.
/ Back seat truck boxes #4
I have not seen them for years. I would try JC Whittney.
My 99 F-150 Regular cab 4x4 had one in it from the factory and so does my 08 Titan. It also has a storage compartment between the left rear and the bumper that hold my straps, 2 draw bars, and 4 ratchet straps. Pretty handy.
Chris
/ Back seat truck boxes #5
I had a Chevy pickup made back in the days when the gas tank was inside the cab behind the seat.
I made a box for it that sat above the tank. It was the width of the cab and sort of a trapazoid in cross section. Just ripped some 3/4" plywood and screwed it together.
Easy to build and probably cost <$20.
/ Back seat truck boxes #6
Fellows, may I shift gears and ask about a seat back storage box (or ANY OTHER METHOD) for my Kubota L-3010. It has no embedded wheelwell box like a JD has. Where do I keep my hammer, wrench, pliers, BEAR SPRAY etc? :confused:
/ Back seat truck boxes #7
This might work for small tools etc
ROPS organizer
Tims link is kind of what I had in mind, not exactly, but probably the best I will find.
/ Back seat truck boxes #10
Good job.....where did you get the shackel bolt? or did you heat and bend a threaded rod?:thumbsup:
/ Back seat truck boxes #12
QUOTE: Good job.....where did you get the shackel bolt? or did you heat and bend a threaded rod?
It is an off the shelf u-bolt from the hardware store with a piece of heat shrink tubing to protect the paint and a spacer to allow the lid to open and close.
(Ammo boxes are bug proof and water tight.)
/ Back seat truck boxes #13
I know what your after. I got mine from Carquest about 3 years ago, but I don't know the brand. I recall paying around $25.00 for it. Is still going strong.
Mike
Medicshawn, that is EXACTLY what I had in mind. I can't tell you how long I spent surfing trying to find something like that, Thanks.
/ Back seat truck boxes #15
Glad I could help I just searched google for truck organizer and got a bunch of hits. Looks like DeeZee makes a couple of different versions.
