I would like to use a dedicated hydraulic circuit other than the aux remotes, just not sure how to do that. The Woods hyd kit bolts on the transmission in the same place that the Kioti remote valve block goes. I don't want to eliminate that and I don't think you can piggy back the 2, if you could that's what I would do. As stated before I think I'll do what Woods recommended and return directly to the tank if I can get the right fittings.
I have given this a lot of thought, and can hit on the highlights thus:
Your tractor's implement pump supplies the FEL valve, then the AUX
valve(s), then the 3PH valve. The last valve (3PH) dumps to the tank.
Most CUTs do it this way.
When the hoe is mounted, you can do without the 3PH, but must have
the FEL. You may or may not want to do without the AUX valve(s),
depending on if you use it for a hyd thumb, or a
grapple on the FEL bkt.
Your hoe valve has no Power Beyond outlet like your FEL and AUX valves
have, so it must be last in the circuit if it is plumbed as a primary valve
in the power beyond pressure circuit. As I said earlier, the best way to
plumb a hoe is as a primary valve in the PB circuit.
Kioti gets around this problem by providing detented work ports on its
AUX valve, and they tell hoe users to connect there. It is a clean and
easy installation, but somewhat of a compromise. If you look at the
Kioti AUX valve, you can see internally that the passages are not large,
certainly smaller than the ID of a 1/2" hose. That (in addition to some
restriction from the high pressure QD fitting) causes some significant
restrictions to hydraulic flow. As I said before, this setup does work, but
I have installed and used the same hoe extensively on tractors that I
have connected to the PB out of the FEL valve, and to the PB Out of
the AUX valve and I got less oil heating.
Note that Kioti does not use QDs between the IN of FEL valve and the
pump, and none between the other valves either. On some Kubotas, the
FEL is connected to the loader, so the IN and PB OUT do have QDs, but
large ones (1/2").
Now, back to the M27 tractors, including yours and mine. The ideal place
to put a hoe is with the hoe's IN after the AUX valve, and the hoe's Out
connected to the tank. The 3PH is bypassed when the hoe is mounted.
Large QDs should be used...I use 1/2" QDs and 3/4" hoses between the
AUX and 3PH, which are connected to each other when the hoe is not
mounted. The problem is, the CK does not use external plumbing between
the AUX and 3PH, so it is hard to get access to the PB Out on the AUX.
Woods may get around this by providing a manifold that connects to the
same place as the AUX valve does. If so, I would like to see a photo
and testimonial from a user. Does it keep you from using the Kioti OEM
AUX valve, or is it stacked on (to the right or left) of the OEM AUX valve?
So, the 2nd best place to put the hoe is connected to the PB Out of the
FEL valve, with hoe Out connected to the tank. (Kioti and Kubota do not
provide many unused ports for the hoe Out, so I have purchased the oil fill
port adapters.) Kioti does have a hardline between the two valves, so you
would need to remove it and adapt it to a large QD and hoses for your
hoe. I am considering this for my CK.
Note that I have chosen to use electric solenoid diverters for my hyd
thumb and 4n1 bkt partially wanting to avoid use of the AUX valve in case
I bypass it in the future. I leave my hoe mounted all the time, but I
turn the AUX valve Off when not using it.
If you decide to do it this way, consult your manual for which line is
which on your FEL valve underneath, or just follow them from the valve.
Accessibility is good.
