Backhoe hydraulic plumbing
/ Backhoe hydraulic plumbing #1
BJN644
Maine
Kioti CK35 HST
Getting ready to pull the trigger on a new Woods BH80X for the CK35. I'm doing the install myself, I have a set of rear remotes on my tractor, but after talking with Woods tech support they recommend running the return line directly into the transmission case to eliminated any restriction going through the quick coupler. My question is, I'm pretty sure I have seen a picture of this setup on this site before, I just can't find it. Is there a Kioti part for this return line set up ? or does anyone have a picture they could post?
/ Backhoe hydraulic plumbing #2
The KIOTI KB24XX Backhoe's are supplied with a kit that allows plumbing through the Quick Connects or an option to plumb directly to tank. The plumb to tank actually goes to the rear transmission oil fill port. Your dealer probably has the fittings and breather for a direct return set up.
We always set up our backhoes to the quick connects. It's a cleaner set up and does not cause any operational problems with the backhoe. It also allows an you to accidentally bump the rear remote lever in the wrong direction without dead-heading the hydraulic system. That alone is reason enough for us to plumb to the quick connects.
/ Backhoe hydraulic plumbing #3
....Woods tech support they recommend running the return line directly into the transmission case to eliminated any restriction going through the quick coupler.
I think dumping the return to the tank is better than to the AUX valve, but
you will still have a QD fitting to go thru. The reason to do it is that
there are restrictions inside the AUX valve itself.
Better yet is to avoid the AUX valve entirely and use the power beyond
circuit.
My CK30 uses the AUX valve for IN and OUT and it works fine, but I think
I can reduce the fluid heating by making one or both of the above changes.
Not high on my list at present.
/ Backhoe hydraulic plumbing #4
I assume that the lines and valves are sized to suit the oil flows that are supplied by that tractor. The only problem I see is if someone downsized something (ie...lines, connectors valves) that were connected to the aux port would be possibly overheating the fluid because of back pressure and then oil being dumped over the relief constantly. My two cents worth.
Steve
Thanks to all that replied.
I would like to use a dedicated hydraulic circuit other than the aux remotes, just not sure how to do that. The Woods hyd kit bolts on the transmission in the same place that the Kioti remote valve block goes. I don't want to eliminate that and I don't think you can piggy back the 2, if you could that's what I would do. As stated before I think I'll do what Woods recommended and return directly to the tank if I can get the right fittings. If anyone has any ideas or picture of tapping into the hydraulic circuit another way I'd be interested.
On an interesting note, while hoe shopping, a dealer that sells the other orange tractor was vehemently opposed to plumbing through the remotes and said that they have had people damage their tractors hyd system by doing this. I have seen several Kioti's run this way and figured thats why the valve has a detent in it, maybe the botas are different?
/ Backhoe hydraulic plumbing #6
The return line is low pressure, and does generate much heat through the quick-connects. The heat is generated through the supply side quick connects at the restriction. This no different that the loader, except the loader uses 3/8" couplers, the backhoes use 1/2". If you are really concerned about heat, use the auxiliary valve plugs and change them to 3/4" Flat face couplers. This will reduce any concern for restrictions.
/ Backhoe hydraulic plumbing #7
I have given this a lot of thought, and can hit on the highlights thus:
Your tractor's implement pump supplies the FEL valve, then the AUX
valve(s), then the 3PH valve. The last valve (3PH) dumps to the tank.
Most CUTs do it this way.
When the hoe is mounted, you can do without the 3PH, but must have
the FEL. You may or may not want to do without the AUX valve(s),
depending on if you use it for a hyd thumb, or a grapple on the FEL bkt.
Your hoe valve has no Power Beyond outlet like your FEL and AUX valves
have, so it must be last in the circuit if it is plumbed as a primary valve
in the power beyond pressure circuit. As I said earlier, the best way to
plumb a hoe is as a primary valve in the PB circuit.
Kioti gets around this problem by providing detented work ports on its
AUX valve, and they tell hoe users to connect there. It is a clean and
easy installation, but somewhat of a compromise. If you look at the
Kioti AUX valve, you can see internally that the passages are not large,
certainly smaller than the ID of a 1/2" hose. That (in addition to some
restriction from the high pressure QD fitting) causes some significant
restrictions to hydraulic flow. As I said before, this setup does work, but
I have installed and used the same hoe extensively on tractors that I
have connected to the PB out of the FEL valve, and to the PB Out of
the AUX valve and I got less oil heating.
Note that Kioti does not use QDs between the IN of FEL valve and the
pump, and none between the other valves either. On some Kubotas, the
FEL is connected to the loader, so the IN and PB OUT do have QDs, but
large ones (1/2").
Now, back to the M27 tractors, including yours and mine. The ideal place
to put a hoe is with the hoe's IN after the AUX valve, and the hoe's Out
connected to the tank. The 3PH is bypassed when the hoe is mounted.
Large QDs should be used...I use 1/2" QDs and 3/4" hoses between the
AUX and 3PH, which are connected to each other when the hoe is not
mounted. The problem is, the CK does not use external plumbing between
the AUX and 3PH, so it is hard to get access to the PB Out on the AUX.
Woods may get around this by providing a manifold that connects to the
same place as the AUX valve does. If so, I would like to see a photo
and testimonial from a user. Does it keep you from using the Kioti OEM
AUX valve, or is it stacked on (to the right or left) of the OEM AUX valve?
So, the 2nd best place to put the hoe is connected to the PB Out of the
FEL valve, with hoe Out connected to the tank. (Kioti and Kubota do not
provide many unused ports for the hoe Out, so I have purchased the oil fill
port adapters.) Kioti does have a hardline between the two valves, so you
would need to remove it and adapt it to a large QD and hoses for your
hoe. I am considering this for my CK.
Note that I have chosen to use electric solenoid diverters for my hyd
thumb and 4n1 bkt partially wanting to avoid use of the AUX valve in case
I bypass it in the future. I leave my hoe mounted all the time, but I
turn the AUX valve Off when not using it.
If you decide to do it this way, consult your manual for which line is
which on your FEL valve underneath, or just follow them from the valve.
Accessibility is good.
/ Backhoe hydraulic plumbing #8
I agree that the return side low pressure lines and fittings do not cause
the greater heat generation. The inside passages of the AUX valve are
quite small, and that is where a lot of the heat comes from. When I add
aftermarket AUX valves, I go with larger units.
Just what I was talking about thanks.
I still like the idea of piggy backing the Woods hydraulic kit with the Kioti aux valve best, I need to research that option more.
/ Backhoe hydraulic plumbing #11
Are you guys in some sort of backhoe digging contest or marathon where every little bit of performance needs to be squeezed out of the machine?
Using the rear remotes for supply and return works beautifully. No muss no fuss. Why use anything else?
Running the return line directly into the transmission sump is how an engineer at Woods recommended I run the plumbing. It's mainly to reduce heat build up in the fluid than to gain performance.
/ Backhoe hydraulic plumbing #13
I understand but unless you are stressing your BH for hours at a time heat build up is just not an issue. If you are using the BH that aggressively then IMO you should have a dedicated BH or mini excavator.
Not sure why Woods would recommend what you are planning over what they know is a much more common and simple hydraulic set up using remotes. Was it Woods or a lone salesperson who advised you?
It was actually a salesman that started this whole thing, he was a kubota dealer and insisted that running a hoe through the remotes would cause all kinds of problems. So, instead of arguing with him I called Woods tech support and they said to plumb it this way, I didn't mention my conversation with the salesman so there was no opinion swaying. Kioti sells a direct return kit so there must be some validity to it.
/ Backhoe hydraulic plumbing #15
Actually, Ed, it is not an aggressive or excessive use of a CUT backhoe
attachment to just do some trenches for several hours at a time. I have
done hundreds of feet of trench over the years, but that is not my
primary use. The oil gets very warm using the hoe steadily for an hour or
more. Too warm? Maybe not. I think many CUT hoe users will want to do
some long trenches or big holes.
For my own tasks, I rarely operate the hoe for hours at a time, so the
work port power approach is not a problem. But in setting up a hoe for
a tractor from scratch, I think it is important to know the best ways of
doing it and the tradeoffs you make. And, if you are starting from scratch,
it may be no extra effort to do it the best possible way.
I like to learn by trying things myself or seeing first hand how the different
approaches work. I think it is important to mention another plumbing
approach here. That is, the approach used on my B21, which is also used on
other TLBs. What they do there is provide a driver-accessible manual
diverter valve that switches the hoe loop in and out of the power beyond
circuit downstream of the FEL valve, without having any QD fittings in
the circuit except when the hoe is attached. This is probably the
ideal setup.
/ Backhoe hydraulic plumbing #16
I understand that there may be a logic and alternative for direct return plumbing, I have just never seen an example of poor performance related to rear remote use. As rear remotes are already present and have additional uses, I'd need more convincing to pay more or accept less convenient alternatives.
Heat build up with BH cannot be any worse than with plowing or other high power activities especially as most of us use the BH at 1500-1800 rpm or well below PTO or max output levels.
You have to get that dealer to install that backhoe properly. The hydraulic lines are also not installed correctly. I normally would not say anything about another dealer, but this is not a very good representation of us who strive to do things right. Check with your dealer and have him check with Kioti on the correct installation of those hydraulics. The return line must be routed into the return tube with the kit supplied with the backhoe and a new vent has to be installed in the side of the case to the left of the top link mount. This may not help the HST noise but it will allow your hydraulic system and backhoe to work properly.
I copied this quote from a dealer on a post for an unrelated issue. I believe this is the kit that Michigan Iron posted.
/ Backhoe hydraulic plumbing #18
No question that you can directly plumb the return but good dealers also use simply the rear remotes. Why pay extra for the optional Kioti kit when the rear remotes do the job?
/ Backhoe hydraulic plumbing #19
I just had an on site conversation with a Kioti product support engineer yesterday. His statement concerning direct return through fill port was if you're a weekend warrior using the remote port should be fine for a backhoe. If you're a contractor or a heavy user of the backhoe the direct return should be used to avoid long term damage due to back pressure. Hopefully I have my information correct, but I clearly remember him stating the direct return was not intended to resolve overheating issues and the remotes work fine for most owners. I hope this helps.
/ Backhoe hydraulic plumbing #20
That makes a lot of sense to me. I certainly fit into the weekend warrior category and can attest to the convenience and adequacy of the rear remote solution.
(2) New 26X9-14.5 severe duty batwing tires on 5-lug batwing rims, Coal Valley, IL (A65640)
(2) New 26X9-14.5...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
8x18 Meyer 1200 H Farm Wagon (A65579)
8x18 Meyer 1200 H...
