Continuous Flow
/ Continuous Flow #1
Believer
I don't understand my tractor's hydraulics yet. If I wanted to run a continuous hydraulic flow, for example to run a hydraulic tool, can I do that with my New Holland TN75? Can I add something to do it? Thanks.
/ Continuous Flow #2
Yes, it is called "power beyond", there should be a "kit" available from NH.
/ Continuous Flow #3
Just a word of caution, keep an eye on your oil temperature. If your oil cooler and reservoir are not sized for continious duty you can overheat the system and damage seals etc...
Roy
/ Continuous Flow #4
Roy
For this intended use, I would an auxiliary oil cooler in the power beyond loop after the "hydraulic tool".
/ Continuous Flow #5
bad idea. The power beyond more than likely feeds the 3 point. Which means there is still high pressure after the "added tool".
Unless you have a return to sump line that you are sending the return oil too, then it would probably be ok.
/ Continuous Flow #6
Good point.... didn't think of that.
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
Informational Lot - Shipping (A63688)
Informational Lot...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
