Continuous Flow
/ Continuous Flow #1
Believer
I don't understand my tractor's hydraulics yet. If I wanted to run a continuous hydraulic flow, for example to run a hydraulic tool, can I do that with my New Holland TN75? Can I add something to do it? Thanks.
/ Continuous Flow #2
Yes, it is called "power beyond", there should be a "kit" available from NH.
/ Continuous Flow #3
Just a word of caution, keep an eye on your oil temperature. If your oil cooler and reservoir are not sized for continious duty you can overheat the system and damage seals etc...
Roy
/ Continuous Flow #4
Roy
For this intended use, I would an auxiliary oil cooler in the power beyond loop after the "hydraulic tool".
/ Continuous Flow #5
bad idea. The power beyond more than likely feeds the 3 point. Which means there is still high pressure after the "added tool".
Unless you have a return to sump line that you are sending the return oil too, then it would probably be ok.
/ Continuous Flow #6
Good point.... didn't think of that.
2017 International HX620 Quint Dump (A62613)
2017 International...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
John Deere MX6 Bush Hog (A64047)
John Deere MX6...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
