Continuous Flow
/ Continuous Flow #1
Believer
I don't understand my tractor's hydraulics yet. If I wanted to run a continuous hydraulic flow, for example to run a hydraulic tool, can I do that with my New Holland TN75? Can I add something to do it? Thanks.
/ Continuous Flow #2
Yes, it is called "power beyond", there should be a "kit" available from NH.
/ Continuous Flow #3
Just a word of caution, keep an eye on your oil temperature. If your oil cooler and reservoir are not sized for continious duty you can overheat the system and damage seals etc...
Roy
/ Continuous Flow #4
Roy
For this intended use, I would an auxiliary oil cooler in the power beyond loop after the "hydraulic tool".
/ Continuous Flow #5
bad idea. The power beyond more than likely feeds the 3 point. Which means there is still high pressure after the "added tool".
Unless you have a return to sump line that you are sending the return oil too, then it would probably be ok.
/ Continuous Flow #6
Good point.... didn't think of that.
STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
STARCRAFT BUMPER...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
Adams Nurse Trailer Tank (A63118)
Adams Nurse...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
