Oil & Fuel Fuelling Up
   / Fuelling Up #12
Can anyone confirm that no.2 fuel oil used for oil fired furnaces in homes is the same as diesel fuel suitable for use in our tractors?
   / Fuelling Up #13
I use 5 gallon fuel jugs, and a siphon arrangement to get the fuel moving.
The long end goes in the fuel can, short end in the tank opening. Close the valve and squeeze the bulb a couple times to get fuel to the valve, open the valve and that's about it.
Sean
   / Fuelling Up #15
Which cartridge do you use with it ?
Yeah, I`m interested too.
I was looking at the filter and water separator that Northern Tool sells. They are the common ones I see on all the pickup-bed mounted, and others.
Yours looks bigger/better?? But also about 4x as much $$
   / Fuelling Up #16
Yes, #2 is furnace oil. Not to be confused with #1 fuel oil which is used for the old fashioned "stove" heaters. I do not believe #1 would do any damage to your tractor, but the BTU output is less consequently less power.
If you live in a colder climate you may have to do some treatment of the #2 fuel oil to avoid problems.
   / Fuelling Up #17
Nearly the same here but a 500 gallon above ground tank and a hand pump
with a Goldenrod filter. Reminds me I need to check the tank and probably
get about 250 gallons since the price is down a bit. Our bigger tractors burn
better than 2 gallons an hour. The L3940 is a real sipper, very fuel efficient.
   / Fuelling Up #20
5 gallon plastic jug. Little tractors don't use much fuel, so I don't need anything bigger. Besides, I don't want to be stuck with too much #2 when old man winter comes around!
Joe
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A58017)
2012 INTERNATIONAL...
2018 Chevrolet Silverado (A55973)
2018 Chevrolet...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
Trailmobile Van Trailer (A56435)
Trailmobile Van...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
Honda utv cart (A56859)
Honda utv cart...
