Oil & Fuel Fuelling Up
/ Fuelling Up #1
Larry Caldwell
Super Member
Myrtle Creek, Oregon
Kubota l3130
So, how do you guys handle your fuel? I don't use that much, so I just have four 5 gallon plastic cans. I use diesel Sta-Bil in each can, since I never know when the weather will shut me down until spring. That way the tractor tank and storage cans are all stabilized.
When I re-fuel, I don't use the spout on the can. Instead, I use a galvanized funnel with a fine mesh screen in the spout. It's interesting how much crud gets caught in the screen, even though I am careful to keep the cans tightly sealed and clean on the outside.
On my parents' farm, we use a truck mounted tank that pumps the fuel through a filter. At that, we have had to periodically clean the whole fuel system to keep the tractor running right.
At both locations we re-fuel at shutdown to minimize condensation in the tractor tank. It's part of the daily shutdown service routine.
/ Fuelling Up #2
Since I live only 3/4 mile from the nearest truck stop:D , I just drive the tractor there and fill up with diesel right from the pump. Sure beats lifting 6 gal. fuel containers up to the fuel fill on the tractor.
Curt
/ Fuelling Up #3
We use the plastic containers for the L5030 and BX2660, but we are getting a tank for the M8540, MF375 and JD2305.
/ Fuelling Up #4
5-gallon cans. I don't like keeping too much diesel fuel in the barn. Hoisting them up in the air is a pain, but that which does not kill me makes me stronger. :laughing:
/ Fuelling Up #5
diesel fuel etc.
The cartidge may be bypassingor have ahole in it
switch to a paired 5 micron filtration cartridge unit and you will have fewer problems with your prime mover.
Saying that installing a Racor model 1100 fuel filter with a thermostaticly controlled fuel heater will remove everything to either 20 micron or 5 micron a little fuzzy remenbering the spec
The Racor passive design relies on the prime movers injection pump and creates a centrifugal flow with director vanes which spins the fuel and the sediment and water collect at the bottom and it has a manual drain to dump it all.
You would not believe how much junk and water collects in tanks whether they are on the prime mover or mobile or stationary storage- weld spatter and chippings from the core wire after cooldown and usually they dont clean them very well either.
Not an issue with diesels-gasoline engines yes but not diesels especially if they are indirect injection.
Your counting on the heat value of the fuel with a gas engine and cold goes to heat with gas engines which creates condensation on the inside walls of the gasoline tank after they are shut down and not refueled with fresh petrol.
They make a bulk fuel filter too- I will find what I have and post it here.
The bulk diesel fuel filter separator moves along at 35 gallons per minute
my thoughts anyway
/ Fuelling Up #6
Owning a BX and only putting 50-70 hours a year on it, fueling is an infrequent thing. For those here who own similar machines and have similar use, we store our fuel at the Fuel Mart near us.:D Our fuel stays fresh and seasonally correct.
A simple 2.5 gallon plastic can. $10 to fill. It's heavy enough from which to pour.
Whole different world for guys with high fuel use.
/ Fuelling Up #7
I go through about 40 gallons of fuel a month..Bring it home in 5 gallon cans. PENNDOT uses the station that I frequent so I know that the fuel is fresh, there are delivery trucks there all the time...My biggest concern.
/ Fuelling Up #8
Just a FYI and I doubt if it will cause a problem with such short term usage but Galvanize doesn't go well with Diesel Fuel as the Diesel Fuel dissolves the galvanized coating (zinc) depositing it in the filters and the engine. That's why you don't want to store Diesel Fuel in a Galvanized container.
Jim
/ Fuelling Up #9
5 Gallon cans for now.
Trying to get a 250-500g gravity feed tank off craigslist for 500 or less.
There's always some on there but they of course are 2+ hours away too :laughing:
/ Fuelling Up #10
I just use a 5 gallon plastic fuel container...Here in Orygun, when I purchase the fuel, I let them know it's for my tractor so I don't have to pay road tax...Not a big thing I agree, but it saves around .24 per gallon...I feel I pay plenty of tax as it is.
Don
/ Fuelling Up #12
Can anyone confirm that no.2 fuel oil used for oil fired furnaces in homes is the same as diesel fuel suitable for use in our tractors?
/ Fuelling Up #13
I use 5 gallon fuel jugs, and a siphon arrangement to get the fuel moving.
The long end goes in the fuel can, short end in the tank opening. Close the valve and squeeze the bulb a couple times to get fuel to the valve, open the valve and that's about it.
Sean
/ Fuelling Up #15
Which cartridge do you use with it ?
Yeah, I`m interested too.
I was looking at the filter and water separator that Northern Tool sells. They are the common ones I see on all the pickup-bed mounted, and others.
Yours looks bigger/better?? But also about 4x as much $$
/ Fuelling Up #16
Yes, #2 is furnace oil. Not to be confused with #1 fuel oil which is used for the old fashioned "stove" heaters. I do not believe #1 would do any damage to your tractor, but the BTU output is less consequently less power.
If you live in a colder climate you may have to do some treatment of the #2 fuel oil to avoid problems.
/ Fuelling Up #17
Nearly the same here but a 500 gallon above ground tank and a hand pump
with a Goldenrod filter. Reminds me I need to check the tank and probably
get about 250 gallons since the price is down a bit. Our bigger tractors burn
better than 2 gallons an hour. The L3940 is a real sipper, very fuel efficient.
/ Fuelling Up #20
5 gallon plastic jug. Little tractors don't use much fuel, so I don't need anything bigger. Besides, I don't want to be stuck with too much #2 when old man winter comes around!
Joe
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
APPROX (50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A65055)
APPROX (50) UNUSED...
