T300 Loader Valve Replacement
/ T300 Loader Valve Replacement #1
les.houston
Member
I have been fighting hydraulic gremlins since May 2009 on my T300 (new model).
Of that fight, I am on my third TYM-provided loader valve in 16 months.
I recently left the FEL in the full up position with a set of pallet forks on it. I had to replace the fuel shutoff solenoid and working on the T300 is best done with the FEL up. While waiting on the part, the curl cylinders dropped (extended) fully and the lift cylinders dropped over a 3 day period, all the way to the ground.
I asked my local dealer and according to the tech at the NC warehouse, a drop of this magnitude over a 3 day period is considered normal...:confused: Hmmm...some drop is expected, but this? Maybe I expect too much...:p
Anyway, I am fed up and replacing it with a Brand Model# LV22RFSTKAB from NorthernTool (Item# 20117) and I also need the PB sleeve. I called NT and they carry it, but do not list it...weird...however, they have it for $18.95.
I asked them to start listing it and they may sell more of both...we will see...
I will post in a week or so to let everyone know if this has fixed this immediate issue and also maybe solves the spongy compression of the curling cylinders that I have been fighting.
Les
/ T300 Loader Valve Replacement #2
Les
Is the joystick mounted right on your vavle? I am working with TYM and dealer to get one installed on mine because mine is the older setup using a joystick with cable system. I have another thread on this.
That Brand valve is the one I was going to put on mine if there was no warranty..or if I run into the same problem you had in the future..
As for the droop there should be some. I have never left mine up, but I will try probably the same valve used...
You had pump problems before didn't you? Did they replace the cylinders on the loader?
/ T300 Loader Valve Replacement #3
If you do a search, you will find acceptable drop rates as set by John Deere and Co. I can't remember what they were, but it was inches per hour, so after 3 days it would definatey be on the ground.
/ T300 Loader Valve Replacement #4
Sorry my brain didn't process the 3 days the first time I read it, makes sense.
I just never left it up because of safety issues. I know my back hoe will drop to ground within a couple days if I don't secure it. Also the 3pt arms will droop over time many days and I have to switch my valve by the seat to raise them off the back hoe subframe.
I've ran tractors that didn't drop a bit over a week. One was a 70's JD and the other a XT90 Allis with an aftermarket setup. Maybe that is acceptable, but sure seems odd to me. But I am odd, I am told...:D I still have to keep hitting the lever to curl the bucket back up every few minutes or so...inches over hours might be doable, but inches over minutes sucks.
The joystick I have is a direct mount with not cables or odd levers. I've read good things about the Brand controls...we will see.
My 3pt will not drop an inch...over weeks. It stays rock solid.
Yes...I had horrible hydraulic issues. They replaced the joystick, both curl cylinders, and the pump. It was the pump replacement that got rid of the air in the fluid.
Maybe I expect too much out of this thing...
/ T300 Loader Valve Replacement #6
Inches over minutes is not acceptable.
/ T300 Loader Valve Replacement #7
Les
Did you order the Brand valve and PB sleeve yet?
When you say 3pt hitch stays for weeks is that with it sitting and not ever running in weeks? because the way mine is set I have a lever to control the rear hydraulics by the seat, it has a top, middle, and bottom position. Middle(default) is 3pt hitch which mine is set for top with a holder I whipped up for use of the back hoe. Bottom is reverse flow to rear. So every now and again I have to move lever to middle position to reset the 3pt hitch because the arms fall down to the back hoe subframe.
Yes...I received the valve and PB a couple of days ago. I now have to figure out what adapters I need...the Brand setup is SAE 8, whereas the TYM is slightly smaller. Trying to research the exact size so I can find the adapters I need.
In regards to the 3pt. I can leave it off for weeks with the 3pt. in the up, middle, whatever position above ground and it won't move/budge from its position unless I move the control to releive the pressure.
I also have the backhoe setup, btw...
/ T300 Loader Valve Replacement #10
Oh don't say "Kenny from NC warehouse says otherwise evidently" because that is who I am and my dealer are dealing with and we both haven't heard a word...on the loader valve replacement yet..
Wow the valve uses smaller the sae 8, I wondered that being and import...
Hope you get yours running good soon, good luck.
Ahhh...to dang funny! Pleasure to meet you! Funny how the story fades through the grapevine.
I just can't see how the rate of drop I have is acceptable. While mowing last night, I had to adjusting every few minutes to keep the bucket up.
I know Kenny at Coleman has been pulling his hair out over this whole thing...and BTW...those guys have been so awesome through this whole issue the last 16 months.
The valve from Brand says SAE8 on its web site. What is the size on the valve on the T300 that I have? It is just slighly smaller than the Brand model.
I love my little T300...don't get me wrong...it is a beast! I just need to get through this hydraulic issue sometime soon...winter is coming...
So...in closing...did not mean to mis-quote you...my most humble apology!
/ T300 Loader Valve Replacement #12
You will probably find it is metric threads. I know the quick connects on my loader are. The only place I found them are through the dealer.My local hyd shop couldn't match 'em so I just put new O rings in. Lots of luck on the threads ,let us know what size they really are. STEVE
/ T300 Loader Valve Replacement #13
les, while mowing you shouldn't have to adjust the bucket at all...
I have done some boxblading this spring and was out there for hours without ever adjusting my bucket.
Yeah...I know...my point exactly. About every 10 minutes or so yesterday, I had to tip the bucket back up. The loader would drop about an inch every 30 minutes or so.
I hope to figure it out...About ready to pull the tap and die set out...
/ T300 Loader Valve Replacement #16
les
Came across this chart thought this may come in handy for you.
OEM TYM size must be Metric M12 with 1.5 pitch then.
http://horizonindustrial.com/files/techdata.pdf
Now may want to check into enlarging the valve up 2 sizes if possible then maybe a sleeve would be available to adapting the OEM fittings.
Just my 2-penny opinion.
Good luck
les
Good luck
Thank you...any and all info is appreciated.
I may have a work around for the banjo fittings. The hoses are only 4' long, so I can replace them with flare fittings like the rest and should be good to go. I will have to pull one of the connectons for the flare and test it on the nipple adapter I bought...
I will take pictures if and when this gets going...
/ T300 Loader Valve Replacement #18
Les,
Pics would be greatly appreciated seeing as I may have to do the same thing down the road some..and others on the site.
Grut
Les,
Grut
There is good news, and then there is more good news!
The JIC connection is a standard size and not metric, so the adapters I purchased along with the purchase of 3 new hydraulic lines to eliminate the bango fitting and a couple of femail JIC fittings, I will be in business this weekend.
I will post all the parts and tools as well as pictures this weekend. Along with my post, I will repost the NT part number for my Brand valve and the info for asking for the Power Beyond Sleeve from NT.
/ T300 Loader Valve Replacement #20
Sweet Jesus!!
Bet you'll be happy when it's over... definetly keep us posted with the acquired information..
I sure hope that fixes your droopy bucket problem.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2016 Lincoln MKC SUV (A61569)
2016 Lincoln MKC...
2017 WILSON DWH-600 4X2 T/A 41FT HOPPER TRAILER (A59906)
2017 WILSON...
DEUTZ MARATHON...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2019 LARK UNITED CARGO TRAILER (A60736)
2019 LARK UNITED...
