T300 Loader Valve Replacement
/ T300 Loader Valve Replacement
The Results are In!
I've given the new valve just over a week to test it out and it appears to have fixed my issues!!!!
I purposely parked it with the FEL in the full up position with the pallet forks on it to see how much it dropped over a 3 day period. To my (not so) surprise, the lift cylinders only dropped 1 inch over that time frame and the curl cylinders did not drop at all.
I ran it for couple of hours mowing this weekend and the bucket did not drop at all.
I can lift and curl at the same time now.
I would recommend this install to anyone who is willing to try it.
I will be posting the pics and a full write up on this later this week...
Les
/ T300 Loader Valve Replacement #22
Glad to hear it works like it should. A post up a write up with pics would be appreciated by many..
/ T300 Loader Valve Replacement #23
Hi Les
I have a 330hst and my neutral post on my joystick just broke. I have been having similar problems and would definitely appreciate a writeup of the parts you used to replace the valve.
Thanks,
Scott
Auger Bit (A64912)
Auger Bit (A64912)
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2016 John Deere 6145M (A64911)
2016 John Deere...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
