Ford 3630 Starting Problems
/ Ford 3630 Starting Problems #1
Griff665
Taylors, SC
Ford 3630
I have a diesel Ford 3630 that will not start. I checked the fuel at the fuel pump (bleeding) and checked the air cleaner for pluggage. Both seem OK.
Any suggestions??
/ Ford 3630 Starting Problems #2
Loosen the fuel lines at the injectors and crank the engine. See if you have a good flow of fuel on all lines. If not, there is air in the line. Continue cranking until you get a flow, tighten the lines and the engine should start (if air was the issue).
/ Ford 3630 Starting Problems #3
there is a electric kill solenoid on the injection pump take it out and there will be ablack plunger and spring remove them and see if it will start if it does u will have to kill it by putting it in high gear and old the brakes but that is what is most likely wrong with it
Any suggestions??
I sprayed Ether in to the air intake and got an attempt to fire. I tried to get to the injectors but the battery tray will not swing out of the way ( hits front dumper brace). I tried to remove the tray but the hing pin will not drop out of the bracket. Any suggestions before I start cutting the tray out?
/ Ford 3630 Starting Problems #6
I would start with simpler things than the injectors. 1st did you try what whodat526 explained? 2nd would be check for plugged fuel filter. I have seen several times in the past few years where tractor seemed to run fine, then not start and it was a bad fuel filter. I don't know if it was dumb luck or the newer fuels, but seems they don't last as long as they use to.
I put on a new fuel filter. I disconnected the fuel line between the tank and filter. No flow. I pulled the line apart and found the line plugged. I cleaned out the line but noticed low flow from the tank. Is there something I can add to the tank to clean it out?
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 CATERPILLAR 299D2 XHP SKID STEER (A62129)
2018 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
80003CFL (A61568)
80003CFL (A61568)
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
