Ford 3630 Starting Problems
/ Ford 3630 Starting Problems #1
Griff665
Taylors, SC
Ford 3630
I have a diesel Ford 3630 that will not start. I checked the fuel at the fuel pump (bleeding) and checked the air cleaner for pluggage. Both seem OK.
Any suggestions??
/ Ford 3630 Starting Problems #2
Loosen the fuel lines at the injectors and crank the engine. See if you have a good flow of fuel on all lines. If not, there is air in the line. Continue cranking until you get a flow, tighten the lines and the engine should start (if air was the issue).
/ Ford 3630 Starting Problems #3
there is a electric kill solenoid on the injection pump take it out and there will be ablack plunger and spring remove them and see if it will start if it does u will have to kill it by putting it in high gear and old the brakes but that is what is most likely wrong with it
Any suggestions??
I sprayed Ether in to the air intake and got an attempt to fire. I tried to get to the injectors but the battery tray will not swing out of the way ( hits front dumper brace). I tried to remove the tray but the hing pin will not drop out of the bracket. Any suggestions before I start cutting the tray out?
/ Ford 3630 Starting Problems #6
I would start with simpler things than the injectors. 1st did you try what whodat526 explained? 2nd would be check for plugged fuel filter. I have seen several times in the past few years where tractor seemed to run fine, then not start and it was a bad fuel filter. I don't know if it was dumb luck or the newer fuels, but seems they don't last as long as they use to.
I put on a new fuel filter. I disconnected the fuel line between the tank and filter. No flow. I pulled the line apart and found the line plugged. I cleaned out the line but noticed low flow from the tank. Is there something I can add to the tank to clean it out?
2001 Vermeer BL2000 Chipper with Grapple (A61166)
2001 Vermeer...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
CAT CB-334E Smooth Drum Roller (A61166)
CAT CB-334E Smooth...
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2015 Isuzu NPR 16ft. Box Truck (A61568)
2015 Isuzu NPR...
