2nd shuttle shift failure
/ 2nd shuttle shift failure #1
deputyrpa
Gold Member
Fort Ann, NY
2006 Massey Ferguson 3635 Cab
Well, with 460 hours on it, my DK45S is in the shop for a second shuttle shift repair. I'm fairly disappointed. I work it hard, doing loader work and pulling ground engagement implements for farming, but I would think it should hold up to these tasks. After all, it's not a lawnmower.
Fortunately, it's still under warranty, but how long will the SS fix last? Has anyone else had problems with their SS with such low hours?
While the tractor is split, I'm having them replace the clutch for the parts cost. That also was worn a bit more than I suspected. Might as well.
/ 2nd shuttle shift failure #2
Deputy, long time no post.
When you say shuttle shift, do you mean the shuttle shift transfer case has let go? What exactly is breaking?
That is something that should be nearly indestructible.
Joel
Apparently it was the synchros and such.
/ 2nd shuttle shift failure #4
is it breaking during a certain use or task? Or just plain ole wore out?
It's popping out into neutral. Started in road gear and quickly degraded to affect 2nd and then 1st. I couldn't even pull a tedder with it.
/ 2nd shuttle shift failure #6
So you're talking about the range gears then? High Med. Low?
/ 2nd shuttle shift failure #7
In talking with a Kioti rep he said the new DS4110 & DS4510 economy tranctors use the same transmission that was (is?) used in the DK series but the synchros were removed and it's not marketed as a synchro-trans because they have seen some problems with the synchros on the DKs.
It's not an ideal solution, but have you considered not changing gears on the fly? It might be the solution at least once you are out of your warranty period.
/ 2nd shuttle shift failure #8
Is it the forward reverse shuttle that is popping into neutral?
That reverser gearbox should be supper simple stuff
I'd have to think on it a bit but would think if it is popping into neutral from both forward and reverse then must be something fairly simple in there going wrong
Joel
Thanks for the info Joel. The local dealer i took it to said that, despite the fact that it is supposed to work while rolling, that one should stop before using it. That farts on it's usefulness a tad. It was ocurring in forward only, in high range. That was enough failure for me to take it in - I didn't even bother trying medium and low. The less metal flinging around in there, the better.
/ 2nd shuttle shift failure #10
Last year, my DK45SC shuttle reverser lever wouldn't stay in gear, especially in reverse (eg blowing snow) and a shift fork(?) was replaced under warrantee. I almost never shift from forward to reverse (or vice versa) while still rolling. Lately (at just over 400hrs) I've noticed a bit more gear grinding than usual when shifting gears in high range...I hope this doesn't foretell a coming problem.
BOB
/ 2nd shuttle shift failure #11
They got all kinda new stuff but,,shifting from forward to reverse,while moving,,just don't sound like a good idea to me?? don't have a hydro,but still,think you'd want to come to stop first.
/ 2nd shuttle shift failure #12
In these machines absolutely need to come to stop prior to throwing the lever from forward to reverse or visa versa
my dozer had a hydraulic reverser which you'd throw while moving it would rdirect oil from front spinning clutch pack to reverse spinning clutch pack in a controlled manner
but my reverser / shuttle shift is all gears in my tractor which are not deigned to be thrown forward to reverse while moving
I've never even tried
Joel
/ 2nd shuttle shift failure #13
Hi Deputyrpa,
In the earlier model DK45S the shuttle shift fork under heavier use could tend to bend at the ends and wear. Thus only having a problem in one direction. When they changed it the first time they may have had an older fork in stock and put it in. The newer shuttle forks are much heavier casting and we have not had any problems with the new replacement.
Make sure your dealer puts in the upgraded fork and makes the adjustments and you should be trouble free.
Good Luck
Dave G.
KiotiDave
Hi Deputyrpa,
Good Luck
Dave G.
KiotiDave
Thanks. The fork was already replaced by Wallace last year, because I had the same problem. Evidently, there is another issue with either design or parts.
/ 2nd shuttle shift failure #15
I just purchased a 2006 DK45S with 456 hours on it and used it for the first time this weekend to brush hog 5 acres. Every thing seemed to work great except i kept having one problem. In third gear high (with and without pto engaged) the tractor would start to go and then jump into neutral. I am not an experienced tractor owner, this is my first one. All the other gears in all the other ranges work fine only the 3rd gear in high. Should i be concerned? Also a light on the instrument panel comes on that is a square with a two circles separated by a line. Its the light to the right of the PTO light. :confused:
Correction!! I has done it to me in other gears also. It seems like the forward on reverse shifter doesnt allow the transmission to get fully engaged in forward, in Reverse it does not do it. Id really hate to load it up and take it to the dealer because its 30 miles away. If someone thinks they know whats up, please let me know.
/ 2nd shuttle shift failure #16
Depytrspa
I purchased a new 06 DK 45 from Wallace and had two shuttle shift repairs for a total of four trips to the Kioti dealer for the 45 jumping out of gear. THe main transmission is jumping out of gear, they spoit the trans and replace a litney of parts. Wallace is no longer a Kioti dealer, shich complicates the problem.
Recently, I was doing some brushing on a steep hay field with a little morning due on the field and the main jumped out of gear. The machine took off, the brakes locked and the machine began sliding faster than I was mowing and would stop. Fortunately the field sloped off to level and I got the machine under controll. Lets face it, it could have been a bad hair day. Kioti has a problem with this model jumping out of gear and should recall all of the machines. The more I read the more I find that the problem is out there and others are having problems.
My problem is Wallace is no longer a Kioti dealer, l have fine months left on my warranty and I need the machine. My point for responding to your message is to let others know that the 45 DKS has trans problems and someone needs to address it. I thought about getting it repaired and dumping the machine, but that isn't a solution, because it is only going to happen to the next guy. I think it's time to make waves.
Good luck,
Frankie D
/ 2nd shuttle shift failure #17
Has anyone experienced this failure on newer (09,10) Kioti's?
/ 2nd shuttle shift failure #19
I am just wondering if the shuttle shift systems are the same on the DK35 and other Kioti models?
This seems to be a potentially dangerous problem, especially if you are mowing hills like one poster has stated...Not a good situation to be in.
Anyone hear anything from Kioti?
/ 2nd shuttle shift failure #20
Here is a good example where Wallace is no longer a dealer will be interested to see what kind of action is taken by anyone if anything.
Joel
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
Back Buddy (A64194)
Back Buddy (A64194)
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
Wagon Wheel Chair (A64557)
Wagon Wheel Chair...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
