Snow Snow removal options
/ Snow removal options #1
Carl Bert
Rockland county, New York
Kubota B26, John deere X595
I have a Kubota B26 and was wondering what my best option for snow removal would be. I have a 100' blacktop driveway. Not big but I still need to clear the snow. My options, that I know of are: 1) Rear mounted snow blower. 2) Front mounted snow plow. 3) Rear mounted grading blade. 4) Or just use my FEL. I also have a John Deere GX345 which will take a front mounted single stage snow blower.
I guess the cheapest way would be the FEL, but not sure if that would damage the driveway. Any input?
/ Snow removal options #2
Carl,
I have a 1000' blacktop driveway (about 600' shared with a neighbor), and I use a FEL & rear blade. Rear blower would be nice, maybe Santa will bring me one someday.
With "only" 100', hard to justify the expense of a blower or front angle blade, but of course that's up to you. You could probably get away with FEL only. This past winter when we got 52" in back-to-back storms, the rear blade was pretty much useless (nowhere for the snow to go), and it became a FEL-only situation (scoop & dump).
One tip though, if you're concerned about not scraping/gouging up your blacktop, you might want to look into a UHMW bolt-on cutting edge for the FEL bucket, blade edge, etc.
/ Snow removal options #3
Carl, I have a 150 blacktop driveway and used my FEL for 2 years before getting a front mount snow blower. Never damaged my driveway but it is time consuming with the FEL. The snow blower is by far one of the best attchments I bought. With a 15 inch snow storm I went from and hour down to 15 minutes to clear. But your FEL would work just fine.
One tip though, if you're concerned about not scraping/gouging up your blacktop, you might want to look into a HDPE bolt-on cutting edge for the FEL bucket, blade edge, etc.
Yeah I have a bolt on cutting edge on it now. I was reading in another thread where a guy replaced the cutting edge with a piece of heavy duty rubber. Sounds good, but where do you get something like that? He used a piece of rubber horse mat. No horses around here, so I guessa rubber horse mat would be a tough find. lol. What do you think?
/ Snow removal options #5
My last house had a 260' paved driveway I cleared for years with a small lawn mower (14 HP) and a snow blade. Even with that I would see pieces of black in the snow(small pieces of the pavement surface) I pushed around. I did replace the cutting bar with a piece of hi tech plastic (UHMWP, ultra high molecular weight polyethylene if I recall correctly. This stuff is expensive but I got a piece from work) that did solve the problem, although it wears quite quickly in this service. I eventually replaced that with a walk behind thrower, and put skids on it made from the same material, worked very well.
/ Snow removal options #6
I've been using my ATV and a blade for my 100'+ driveway for years. Only last year did I run into issues simply because of so much snow. It was just too high even though I try to keep my rows a little wider than the driveway when possible. But sometimes that isn't an option. A couple drives I did were down to one car lanes.. and even that was tight.
I didn't have my BX then so FEL was out of the question. So, the last couple storms I whipped out the old walk behind blower and it actually took about the same time as the blade does (when it's not too high).
So, if I was to get anything, it would be a blower for my BX. And then I may start doing neighbor's driveways more too (last year got too much for just "donations", which most don't even consider).
I thought they would be a front mount blower for the BX.. sounds like it may be rear mounted. That would work good I guess since then you could still use the FEL for smaller things and piling up snow.
/ Snow removal options #8
Rubber might be inexpensive, but I think you'll be replacing it every so often.
Fred is correct, the stuff I was really thinking of was UHMW, which is an even denser and longer-wearing polyethylene than HDPE (thanks Fred. :)).
For a ready-made edge, this product comes to mind:
Specialty Items - Poly Blades | May Wes Manufacturing Hutchinson MN
It is expensive, for my 60" bucket I was quoted about $350 thru my dealer. The extra wrinkle for you might be getting it to line up perfectly with your existing cutting edge bolt holes.
I decided I was going to buy an appropriately-sized strip of UHMW for about $75 and machine it myself, just due to one project or another I haven't gotten to it yet. I also hoped to come up with a way to attach it similar to my toothbar, that didn't require drilling holes in the bucket lip. In the meantime, I've just tried to be careful and gentle... the skid shoes on my rear blade keep it from digging in.
When you say it wore out quickly, approx. how long does it last? Did it have to be changed each season? According to DiezNutz it costs about $75 for a 50" length. So lets say $90 for the 60" that I need. If it would last 2 or 3 winters it would be worth it. One year, not so sure.
/ Snow removal options #10
Are you sure you can't get a two stage snow blower for your JD GX345? I would strongly consider this if the comparison cost makes sense. Snowblowers are very effective unless you have light snows. I have a JD LX188 with single stage snow blower and it does a fine job, especially in smaller areas and heavier snows. For 10 years I moved snow with a Ford 8N, tires chains, and a back blade. Thank goodness those days are over. The back blade is not the most effective tool for moving heavy snow. I maintain about 450' of blacktop driveway. This L3940 and front blade is a very quick and effective. Philip.
/ Snow removal options #11
I am using a BX2660 with a front mount snowblower and a rear box blade. I have a 850 ft asphalt driveway. This beats the atv and plow, or skidsteer with loader or blade that I have used in the past. I no longer have to worry about where I will put the next snowfall.
A lot depends on how much snow you get and is it heavy or light snow.
/ Snow removal options #12
UHMW is fantastic stuff !
I don't have my tractor set-up for moving snow yet. If I do, I think I would like to have a rear mount blower.
I have a plow on my 4X4 truck for moving snow. I fabricated a back-drag
scraper for pulling snow away from my overhead door. I used a strip of 3/4"
thick UHMW for the edge, and it works great ! It doesn't make a lot of noise,
either when draging on the concrete.
Carl,
I believe to get the proper plow set up, for my skid steer attachment, would cost about $4000. A rear mounted blower would be around $2500, a blower for my John Deere is $2400.
I realize they are all overkill for such a small driveway, but so is my B26 for only an acre of land. I am purchasing this equipment now because I am able to wright most of it off through my business. That won't be the case in another 5 yrs or so. I am also going to be moving further north, with a much larger piece of property. So I am trying to take advantage of the savings now along with the fact that the price of tractors has been, and continues to climb rather quickly
I would go with the rear mount blower, but it just doesn't seem very enjoyable to use.
/ Snow removal options #14
About your snow etc.
believe me a snow blower for your driveway is not overkill when it is buried in
an ice dam created by the plow when they salt and it melts
You can purchase a front mount 3 point hitch with a gear box from Pronovost/Hardy and atach arear mount blower to the front of your tractor.
you would need a dual hydraulics on the blower-to turn the chute and tilt the spout.
A Pronovost Puma snow blower and the Hardy front hitch with gear box can be bought from a pronovost dealer directly.
I will recheck the buctrac home page as they build pto adapters to run the rear PTO all the way to the front of a standard tractor
The pronovost dealer in weedsport is Tudor and Jones
leonz
/ Snow removal options #15
I'd like to get an Erskine rear pull snow thrower and leave the FEL on. That way I can drive forward to use the thrower, and still have the FEL available to carry beer back to the barn. Last I checked that rear pull thrower was a few pennies under $5K, ouch.
/ Snow removal options #16
I think the method you use would be a function of four things -
How much driveway you have?
How much snow you get?
How much money you want to spend, and
How much you value comfort?
I have 600 feet of driveway. We get 15 to 30' of snow (25 plus snow blowing sessions per year). Money wasn't much of an issue and having taken care of my driveway for 27 years, comfort was a big issue.
The choice was obvious - a tractor with a heated cab, plenty of lights and front blower. With this setup I can move snow 24/7 so the snow never overwhelms me. If you asked me my favorite time to snow blow, I would say in the middle of the night during a blizzard. For me snow blowing is fun.
If I had a short driveway with little snow, I would hire it done or use a cheaper method (rear blower, plow). Using a FEL is just too slow.
If all I had was an open station tractor with a rear blower or a FEL, it would be an unfun job - something I would have to do, but I would hate and dread having to do it.
/ Snow removal options #17
For only 100' of drive, and considering you have been doing just fine in the past with only a FEL, I'd opt to save the $$$ and get a backblade.
They have a huge advantage over the FEL as they can angle. And you still have your FEL on and can pile. It may not be quite as fast as having a blower, but a FEL w/blade combo is a lot faster than just a FEL.
/ Snow removal options #18
I think snow removal methods are determined by your lot...and your winds. I like to move the snow a considerable distance so I don't get "snow blocked" through the season. As well, it better allows me to control drifting with successive storms. How broad are your removal areas?
A blade is fine if you have room for the snow close by. If your neck/back can take it I'd go the rear route to preserve the bucket operation. If you are looking at serious snow, I'd pick the front blower.
/ Snow removal options #19
Yeah, it's pricey... but it's real hard to beat a front blower!! :thumbsup:
(Even on an open station SCUT!:laughing:)
  • 2:23:09-1.JPG
leonz
I would be very interested in this set up. I never heard of running a front mounted implement off a rear PTO. If you know of an sites with more info, please let me know. Thanks
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2002 POLAR TANK (A60736)
2002 POLAR TANK...
2011 Jacobsen T-700 Commercial Reel Mower (A61567)
2011 Jacobsen...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
DEUTZ MARATHON...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
