Suspended Concrete Floor
/ Suspended Concrete Floor #1
pchironb
Hello,
I came across a post here in which a fellow received some good advice with this type of construction. I am looking for any comments or advice as I am not a professional builder rather "acting as my own general contractor".
I am building a home in Central Oklahoma and am interested in a 4" suspended concrete floor on top of a walk-out basement. My reasons for this are as follows:
1. Allows a quick dry in of the basement for interim living / storage while saving for the materials needed to complete formal dry in.
2. Protection from tornados / weather.
3. Sound deadening / insulative characteristics.
Here is my proposed design:
1. Basement dimensions are 30' x 40'. A 39lb/ft Wide flange beam splits the long dimension supported by posts equally spaced and secured into the basement wall. This reduces the 30' span to 15'.
2. Joists constructed from 8" C purlin are welded into receiver channel and are spaced every 12". The receiver channel / Joist ends bear (Welded to 1/4 in plate steel) on top of the basement walls and the top of the wide flange beam. Joists are tied together with flat strap to prevent twist.
3. Q-paneling (14 gage waffle panel) is installed over the joists. Knock outs are installed for electrical / water etc.
4. 2x4 Base angle (14 Gage Angle shape) is welded to the perimiters in order to form or hold the concrete in place.
5. Half inch rebar is placed on 12" centers.
6. 4" of concrete will be poured on top.
Any analysis, concerns, critiques or comments on this design is much appreciated.
Best Regards,
Pete
/ Suspended Concrete Floor #2
I think it best to have a PE take a look at it and decide if it is up to code
/ Suspended Concrete Floor #4
/ Suspended Concrete Floor #5
Best be looking at some proper design advice. Even the pour may need engineering!:)
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A68842)
PALLET OF 51 X 41...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
