Rotary Cutter Ever seen a Bush hog like this? Offset.
/ Ever seen a Bush hog like this? Offset. #1
Slacker
Gold Member
Durham, NC
Farmtrac 360 TLB
Ever seen a Bush hog like this? Offset. PIC FIXED
This one can offset to one side. Pretty neat idea. Would certainly help when doing ditches, but I don't know how stable the machine would be.
/ Ever seen a Bush hog like this? Offset. #3
what no picture? dont torment me this way!!!!!:licking:
/ Ever seen a Bush hog like this? Offset. #5
Agree with the excessive drive line angle, but there is also something missing. Both left and right hook-ups are there for the center hook-up, but the right support is missing for the left (offset) hook-up. Am I missing something?
David
Could this have been modified for a much larger tractor (wider three point hitch set-up)?
/ Ever seen a Bush hog like this? Offset. #6
David
Ya, the pins a kinda screwy aren't they.??
/ Ever seen a Bush hog like this? Offset. #8
We have a Hardee 6' offset bush hog. They have been making them for 30+ years. The first one we had was a 5' combo center-offset rig similar to the one pictured(but the 3pt linkage was a little better designed). The one we have now is 6' and is only used in the offset position. The U-joints do constantly run at an angle and have to be greased every 4hrs. On our IH 454 tractor the 6' cutter sticks out about 18" to the right side, great for getting closer to pond edges, cutting back brush along the woods, etc. The only drawback is that all of the weight is on the right lower 3pt link which can make it hard to level, also takes a tractor with a pretty stout 3pt hitch.
/ Ever seen a Bush hog like this? Offset. #9
the big thing i see is an excessive driveline angle. that'd have to be hard on U joints
I guess if your tractor was offset with one axle nonger than the other the driveline may not be an issue.. however the pin setup is odd..
soundguy
/ Ever seen a Bush hog like this? Offset. #10
Interesting. Obviously a "homemade" job that isn't quite finished yet as the offset mount is not all there.
Stability? Don't know but if you didn't get too wild with it you'd probably be okay.......too small a tractor or too steep an angle would make things hairy.
The offset cutters above are designed from the get-go as pure offsets rather than a "multi-mount" like the one you picture and I like the idea.
/ Ever seen a Bush hog like this? Offset. #11
It would be good for cutting around a pond.Neat looking.
Army Grunt
/ Ever seen a Bush hog like this? Offset. #12
Looks to me like the center part ( connecting pin )what would typically be the right bracket/pin has the ability to move over, note: look at the deck and see the angle iron, my guess is the center moves to this location when using it in the offset position ;)
/ Ever seen a Bush hog like this? Offset. #13
Bush Hog made offset rotary cutters years ago but not sure about now. I bought a Bush Hog 84" offset cutter about 15 yrs ago and it worked fine till I traded for an 8 footer. It was offset to the right side and the drive shaft was angled like the one above. Never had an issue --- just have to keep the joints greased.
edit/add: just checked Bush Hog website and they do offer several offset models.
/ Ever seen a Bush hog like this? Offset. #14
Looks like it is old machine to say the least. It looks like that someone wanted it differnet in design!
I see a lot of work left to make it safe and functional.
/ Ever seen a Bush hog like this? Offset. #15
I have the Hardee manual for this,you take the bolts out of the bracket and rotate the gear drive,you can see the studs sticking up out of the deck where you rotate the gearbox to and bolt it back down
3147 (A63117)
3147 (A63117)
Steiger Bearcat ST220 (A64911)
Steiger Bearcat...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
(6) 5-Spoke Dayton Hubs (A64912)
(6) 5-Spoke Dayton...
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
2013 FORD F-150 (A67714)
2013 FORD F-150...
